Hi Rainer, the problem I could see with that is that it is not unusual to want to delete or hide the input curves that were used to create the surface.
If only some of the input curves remained selected, it seems like that would make that particular task more difficult...
So I'm not completely certain about making that change by default, I'll have to think about that one a bit and about the possible negative side effects.
However, I have included here a customized version of the Sweep command that deselects the sweep rail like you want - if you copy this version over top of the old version inside of the current v2 beta's \commands folder, then your version of MoI should behave like that.
