Assign Shortcut to mouse button
All  1-2  3-7
2428.3 In reply to 2428.2
Hi Burrman, thanks for the tip!
So, I guess there's no mouse button binding directly in moi...
Marc
2428.4 In reply to 2428.3
Hi Marc, no there is not currently a way to assign a custom script to the mouse buttons.
But in this case, you're talking about hitting the Alt key anyway, so I'm not sure there is a whole lot of difference between that and just using a different shortcut key to do it?
I know that several people have made the Space bar set up as a shortcut key for that particular thing, since some other apps like XSI do it in that way.
2428.5 In reply to 2428.4
Your'e right i could use a key but i'm kind of short on keys near the left hand!
It sounded intuitive to associate mmb to a view-related command.
I currently use space to "show points/lock objects" which I'm quite used to.
It won't be a big problem to use an external app to bind the mouse as per Burrman's suggestion.
Thanks!
Marc
2428.6 In reply to 2428.5
Hi Marc, maybe Alt+Space is another possibility...
2428.7 In reply to 2428.6
Will try, thanks!!
Show messages: All  1-2  3-7
