Request advice on battle rider
All  1-4  5-7
2416.5 In reply to 2416.4
Another way Yen may be to do "components".
Create 1 large base shape, keep a copy up an off to the side, then start cutting your components out of copies and moving the cuts to the assembly. If you have cuts that intersect with a previous part, move the cutting curve with it and make the "fitting" cut in the assembly area.
Burr
2416.6 In reply to 2416.4
Hi Yenmonger also this tutorial that lyes did a while ago on doing the deforming spheres technique may be of interest to you:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1514.1
2416.7
Would it be appropriate to offer a bounty/reward here for someone to design this for me? I just need the curvey shapes. I can do the panel lines and more mechanical bits.
It seems that I have gotten good enough at MoI to stay busy doing conventional designs for other people and myself, but can't spare the time to experiment with these wacky curves.
I'm thinking a _minimum_ reward of $50, plus a few copies of the ship once I finish design, print, and cast in resin.
The job would include supplying me with files representing interim design steps so that I can learn the necessary tricks.
Show messages: All  1-4  5-7
