Center to origin
All  1-10  11-12
2409.11 In reply to 2409.9
Hi nameless,
> I am trying to run this script with a shortcut and the selected object disappears.
> When I run it via the script menu at the bottom, the object is centered as expected. Any ideas what could be wrong?
I can't repeat the problem over here, does it happen just with a particular object? If so can you please post a .3dm model file with the object in it?
2409.12
Thank you for looking into this. I found what the problem was- Numlock was not pressed when I tried it, so it somehow registered the period as a coordinate or size input.
Trying again with Numlock on and the script works, object is centered just fine.
Apologies for wasting any reader's time with this. :\
Show messages: All  1-10  11-12
