Center to origin
2409.1
Sorry if it has allready be asked, but is it possible to create a little scipt to center (move) a selected entity (surfaces, solids, curves) to the world origin ?
(not sure if the request is clear :))
2409.2 In reply to 2409.1
Hi PaQ, yup this is pretty easy to do now since a couple of betas ago I added some stuff so that scripts could access an object's bounding box.
Take the attached file CenterAtOrigin.js and copy it to your v2's \commands sub-folder.
Then set up a keyboard shortcut with CenterAtOrigin (note, no .js at the end, and no script: at the start, just that plain name) as the command part and that should do it.
Please let me know if it does not work for you.
EDIT: Updated attachment to new version that centers object at the cplane origin if there is a custom cplane set, otherwise at world origin.
EDITED: 15 Feb 2009 by MICHAEL GIBSON
2409.3 In reply to 2409.2
Perfect Michael, thanks a lot !!!!!
2409.4
Extremely useful.
Thanks Michael (and thanks to PaQ for asking this... Hehe)
2409.5 In reply to 2409.4
Hey happy it's handy for you Schbeurd :)
Just a other question, is it possible that the 'center at origin' works with the cplane too ? so the selection is center to the cplane origin when you're using a cplane, or to the world when cplane is off. I hate to fell like I'm at in a scipt-supermarket, but it's really not my cup of tea, so thanks for you help.
2409.6 In reply to 2409.2
Thanks very much for making this & Thanks to PaQ for requesting it.
FWIW I'm using F4 as my keyboard shortcut so it'll match up for use when I'm using Rhino.
regards Colin
2409.7 In reply to 2409.5
Hi PaQ,
> when cplane is off.
Yup, it's only a tiny adjustment to make that work.
I've updated the attachment to that previous message
(http://moi3d.com/forum/index.php?webtag=MOI&msg=2409.2)
to work like that now, so just copy that new version over top of the previous one.
2409.8 In reply to 2409.7
haaaaa really cool, thanks for taking a bit from your time to this script Michael !
2409.9
I am trying to run this script with a shortcut and the selected object disappears.
When I run it via the script menu at the bottom, the object is centered as expected. Any ideas what could be wrong?
edit: I remember it was working fine at some point- no idea what changed
EDITED: 27 Feb 2022 by NAMELESS
2409.10 In reply to 2409.9
Is the object too small to see? , or is it located outside of the viewing area?
2409.11 In reply to 2409.9
Hi nameless,
I can't repeat the problem over here, does it happen just with a particular object? If so can you please post a .3dm model file with the object in it?
2409.12
Thank you for looking into this. I found what the problem was- Numlock was not pressed when I tried it, so it somehow registered the period as a coordinate or size input.
Trying again with Numlock on and the script works, object is centered just fine.
Apologies for wasting any reader's time with this. :\
