NURBS vs Polygon modeling?
2400.1
just trying out MOI (for just a few days), and like it so far....have been using C4D, Hex, Cararra, Bryce.
What advantages do you see of NURBS over polygon modeling? I would think
that polys, points, & edges give you more control over details(?)
Cal
2400.2 In reply to 2400.1
Hi Cal,
> I would think that polys, points, & edges give you more
Well, they pretty much do! But the problem is that you end up forced to work on that "detailed level" much of the time, trying to manage a large sea of points and edges.
If the object that you are trying to build has a strong 2D profile element to it, the NURBS modeling method allows you to do a lot of work with 2D curves and then cut your object with those curves. This is a very fast way of working for the kinds of shapes that are suitable for this kind of a thing, which tends to include a large amount of mechanical or industrial man-made type shapes.
An easy way to see this in action is to just look through the video tutorials here:
http://moi3d.com/1.0/docs/tutorials.htm
Those give a good overview of how quickly you can create industrial structured kinds of shapes using NURBS modeling. Try building any one of those shapes in a polygon modeler and you will be spending a lot more time wrestling with those details to get your final result.
For things like Character models, faces, stuff that is organic with a lot of wrinkles and things like that, those are things where the detailed control of polygons is very well suited for and they don't map well to a 2D profile driven type workflow, so those are things that tend to work better in a poly/sub-d type modeling system rather than NURBS.
Neither method is the perfect tool for every single kind of model - and that shouldn't really be a big surprised because the field of modeling is incredibly vast!
For mechanical shapes in addition to speed NURBS also gives you a high degree of accuracy since booleans and cutting operations work much more effectively and also accurately with NURBS models rather than with polygons.
But like I mentioned, the best method really depends a lot on your current task at hand...
2400.3 In reply to 2400.2
I am finding, more and more each day, the extent of "poly" type modelling one can actually do in MoI.
Ok, there are things where one can need to take the file into a poly app and finnesse still--especially with displacement painting---and, obviously render. But not a great deal.
Brian
Size: 114.7 KB, Downloaded: 174 times, Dimensions: 1024x640px
2400.4
Michael,
thanks for the insight, and MOI!
....I'm hooked....just need to save up. =)
I'm appreciating what I can do with it quickly.
Attached is a jar (300k .mov) I made in MOI, then rendered
& animated in C4D.
Brian, thanks for re-introducing me to this cool program!
I tried it 2yrs(?) ago, and didn't realize what it could do...
it looked deceptively simple...LOL.....now I know simple doesn't
mean incapable or powerless.....simple saves time & frustration.
MOI is simply great! =)
Cal
2400.5 In reply to 2400.4
Hi Cal, that's a great result!
> now I know simple doesn't mean incapable or powerless.....
Yeah this is something that I kind of struggle against - it is easy to mistake that.
People are just accustomed to powerful programs also having a huge amount of complexity with them, that is kind of how things naturally drift towards. It took quite a lot of work to make MoI avoid this natural tendency.
2400.6 In reply to 2400.5
"that's a great result!" -Michael
Thanks! One thing just led to another...I'll
try to improve on it.
I hope you can continue to improve MOI while
still keeping it "simple". =)
Amazed that you are coding it by yourself.
BTW, if we have any requests, do we make them here
or is there a special link to a Wish List thread?
Cal
2400.7 In reply to 2400.6
Hi Cal,
You can either post them here, or if you want there is a wiki page for that which you can add to: http://moi3d.com/wiki/Wishlist, but you have to create a sign-in for the wiki to edit it (helps to cut down on spam).
If you post it here I can just put it on the wiki for you if you want.
2400.8 In reply to 2400.3
Brian,
great modeling, mate! What's the wingspan on that insect? =O
What's the genus & species, or the "common" name?
-Cal
2400.9 In reply to 2400.8
It's a common name (on all 3D Forums)
It's a "Brinsfantasticaimaginitus"
Brian
