MOI3D mesher plugin for Rhino? Closed
 1-15  16-35  36-55  56-75  76-93
2398.16 In reply to 2398.13
Yannada - To replace Rhino's mesher, MoI won't need an SDK of it's own. The plug would have to run inside of Rhino, using Rhino's SDK. I'm sure Michael is already quite a master of Rhino's architecture. So how difficult would it be to port the code? That's something I have no idea. I'm just a dumb software user... :P
jonah
  More Options
2398.17 In reply to 2398.15
>> Hi PaQ I think what Jonah suggesting it really makes seance, what are you thought on a that? Do you think a plugin for MoI will be better? I will like you opinion on that before I contact the
Tspline guys.
Hi Yannada,
Sorry, I was not talking about the meshing plugin question for Rhino, I just take the opportunity that Tom Finnigan was there to say 'hello, I wan't T-spline for MoI' =)
I know it was allready discussed, and I understand the 100 reasons it will not happend soon, I just didn't resist :P
  More Options
2398.18 In reply to 2398.5
Hello Micheal,
>the v2 standalone will be going up in price a bit I think.<
With full respect of your ability, please be cautious of the pricing. I would agree that V1 was sold under -priced but that gave the base price based on its functions. I know you have worked hard and many many hours on the update, but would not like to see maajor increase in price which may put off new users/ or owners of V1
Many will look at what functions are in V1 and compare to V2 and then associate the pricing.
Please dont jump up and down on me for this comment, it is just my thoughts.
Regards and respect,
- Steve
  More Options
2398.19 In reply to 2398.17
Ooops I missed this one (yes sir we want it too)
  More Options
2398.20 In reply to 2398.9
Hi Jonah,
> Why not just create a method to export the mesh objects
> to a 3DM file. then we import 3DM to Rhino and all layer
> names, groupings, etc can be preserved?
That would solve that particular problem, but possibly cause some other confusion about exporting in 2 possible different ways to the same format.
MoI is able to determine which file format to use based on the file extension - for example if do a "SaveAs" you can just type in c:\test.obj without altering the file type dropdown in the filename dialog, and MoI sees that you are using an .obj extension and therefore knows to export an .obj file.
But if you have 2 different formats using the same extension.... That mechanism will not work to differentiate between them.
Another difficulty is that MoI will not read polygon mesh objects out of a 3DM file, so writing polygon mesh data from MoI could pretty easily lead to confusion as to why some 3DM files that you save cannot be loaded back into MoI. This could be particularly bad since 3DM is the primary file format for MoI.
Note that Rhino does not itself have a method to do a "SaveAs" to a Polygon-only 3DM file (with the mesh conversion done during the save process as per other poly file formats) for these same kinds of reasons.
I suppose it is something that could be added that was only available for scripts and not as a normal part of the UI. But that would probably only be of use just to a Rhino plugin and not really for other general purpose use, that means it will probably be difficult for me to make that work a priority anytime soon, compared to other functions that are more widely used - same as how making a Rhino plugin myself is hard for me to make a high priority.
  More Options
2398.21 In reply to 2398.16
Hi jonah,
Not horribly difficult... But not like a drop-dead easy thing neither, it would certainly need an investment of time, probably about as much as the overhaul for sweep that I want to do in MoI.
The big problem is that is just the tip of the iceberg - forking a codebase tends to create additional work over the long term for maintenance, like applying bug fixes in multiple places rather than in a single place.
Similarly adding new products adds additional support overhead for me as well.
I don't really like to do things that will add to my future work load, so that's basically why it is not too likely that I will be able to invest time in this.
The payoff would seem to be fairly minimal for me as well, since MoI has such a very low price currently and already works very easily in combination with Rhino already. The current version is already working well for a lot of people who would benefit from this function. I have been contacted by a few Rhino users who are looking for a plugin version since they want it to be lower cost than the current cost of MoI. But this is a pretty small number of people, I pretty much figure that if $195 is too much for someone, I'm not really very sure that they would really be able or willing to buy a plugin neither.
  More Options
2398.22 In reply to 2398.18
Hi Steve,
Currently my plan is to increase the price of v2 by US $100 to a total of $295 for a full license, or $100 for a v1 to v2 upgrade license.
Then probably after about another year's worth of work for v3, I think the same thing will happen for it, that it will go to $395. By that point in time quite a lot of the things that were missing in v1 will be filled in pretty well.
One idea that I have had is that in the future I could still offer version 1.0 at its same current price as a kind of "lite" version for someone who was looking for just an essential modeling tool that is easy for them to use. I'm not completely sure about that yet, but that is one idea.
Basically I did end up pricing version 1.0 too low. I mean there were some reasons I did this, I wanted to make it easy for people to get MoI and also having a low price tends to make it easier to justify missing functions. As time goes on and functionality increases, that basically removes one of those reasons. Then that leaves me with accessibility as being the main reason to have a low price. Unfortunately it seems that this only works very well from a business standpoint if you also invest a large amount of effort in marketing to reach people. That's not really something I enjoy doing a whole bunch, so that basically leads me more towards focusing on more professional level users who can more easily afford anything in the $500 range if it helps them get their work done.
No, no problem - I'm sure there will be plenty of people who will be upset at any price increase at all. Then at the same time there will be plenty of people who won't care at all! I would kind of go a bit crazy if I worried about the first group all the time though. I mean there have been a bunch of people who have told me that I should make MoI open source and available for free and that I could pay my bills with the good karma that this would generate! :)
  More Options
2398.23 In reply to 2398.22
At one point Hexagon was $1.99.
Double CAD XT--free
XSI Mod Tool--free
ViaCAD $99
Blender--with Nurbs(big Nurbs update coming)---free
3DCoat---update from V2 to V3 will be $80 (HUGE difference in what is in V3)
Jusat food for thought
Brian
EDITED: 13 Feb 2009 by BWTR
  More Options
2398.24 In reply to 2398.23
Hi Brian, that's great if those cheap/free apps do what you need!
MoI is more of a "finely crafted" type product, it especially takes a long time to do a very high quality UI design.
If you don't place a lot of value on the highest quality UI and workflow, then probably MoI is not going to be the right choice for you, you should use one of those free programs instead if price is your overriding concern.
Just more food for thought! :)
  More Options
2398.25 In reply to 2398.22
Insane!!! I will be able to purchase MoI V2 for $100.00???? This is unprecedented for the type of application we're using here.
  More Options
2398.26 In reply to 2398.25
hear! hear! Burr.
  More Options
2398.27 In reply to 2398.26
In AU dollars US$100 is nearly a full weeks pension.
Brian
  More Options
2398.28 In reply to 2398.22
Increasing the price sounds reasonable to Me as MoI grows to a Professional app. Lets say MoI reaches the $500 or even $1000 price point at V3 or V4, WHAT are the features you plan to add?
For example will you add features like Product Documentation, Industries Standard formats like RealDwg, will you create partnerships with CAM Software...These are important features IMO to have in terns of getting the work done.
Thanks in advance.
  More Options
2398.29 In reply to 2398.27
Hi Brian, I wish I could make MoI available for free, but I have bills to pay and when I tell them to lower my bills they don't seem to listen to me.
So I'm sorry - if US $100 is too much for you, I guess you will need to stay with version 1.0 in that case. Version 1.0 is still a very solid program and can get your models built though!
  More Options
2398.30 In reply to 2398.28
Hi Yannada, longer term I think it is more likely for MoI to kind of cap out at around $500 rather than $1000.
re: what features to add - that is not entirely set in stone, but certainly modeling things quickly and easily will always be more of the primary focus, then at some point more "communication" type features that help you to illustrate your design will come more online, things like some basic dimensions, basic rendering, stuff like that.
It's still not really a particular goal to necessarily replace any other software that is being used, the main goal is more about being able to get certain kinds of things done really quickly.
  More Options
2398.31 In reply to 2398.30
I am only trying to make a sort of "international" view point.
Aussie is one of the richest countries yet the National government is spending huge amounts of money to ensure that all primary school children get access to computers.
The problem is that the schools do not have the funds to buy the apps to get the computers to work!
Brian
  More Options
2398.32 In reply to 2398.31
Hi Brian, will it help me to tell my bank that they should lower my mortgage payments because people in other countries need to use my software for free?
I just don't understand how you would expect for me to run a business without charging any money for the work that I do.
If you know of a way to make this work, I'm afraid you're going to need to explain it a lot more clearly to me, I don't understand how that would work right now.
I mean I can understand how it could lead me to bankruptcy and to foreclosure on my house and a lack of food for me to eat... But those are things I am rather intent on avoiding!
  More Options
2398.33 In reply to 2398.30
Sorry Michael your answer is either diplomatic or you are not entirely sure what is gonna be. On the other hand you have a price set. If you don't mind me saying that is bit confusing for me, Sorry.
Well by adding dwg or Product Documentation support It does not mean that you trying to replace Autocad or Rhino...
  More Options
2398.34 In reply to 2398.33
Hi Yannada, well the truth is that I do not have anything firmly set.
re: Product Documentation - I expect to have stuff in this area, but it will be likely to be targeted towards more informal things. For example probably not a huge list of arrowhead styles and spacing controls for gaps between arrows and leaders, and ANSI compliant stuff, like the stuff you would expect from a full drafting table type mechanism.
So I guess it depends a bit on what your specific definition of "Product Documentation" is.
  More Options
2398.35 In reply to 2398.34
Ok I am not expecting MoI to become a full drafting app. But basic dimensioning tools will help to push the envelop. Also a Dwg support I think is necessary even if I hate this format with passion.
thanks for you reply.
  More Options
Show messages:  1-15  16-35  36-55  56-75  76-93
