monorail: front compartment.
All  1-2  3-7
2386.3 In reply to 2386.2
How about a network of curves and a boolean merge of curves and surface?
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
EDITED: 4 Nov 2010 by MICTU_UTCIM
2386.4 In reply to 2386.1
I did this with fillet, but maybe because we used different numbers and my fillet numbers just fit???
Thought it looked close.
Burr
2386.5 In reply to 2386.1
Hi telnoi,
> Issue, the fillet radius is limited due to the construction of the loft.
If you could post a 3DM model file with the lofted surfaces in it, that may help me understand what issue you were running into here.
Maybe you are trying to loft around a tight bend, when you may need to instead make that a sharp corner and rely on filleting to round it off as well as the other corner?
I would probably normally think of doing what you show there with filleting like Burr shows.
Some other ideas from some previous posts:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2164.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=2164.4
2386.6
hi all here is one off the solution!!!!
loft the 2 curves miror surface and blend edges G2
2386.7
Thank you all for your suggestions. I will have to try them out in a couple of days from now, as my job requires my full attention atm (no time for playing). I will post a few screenshots of the result in the near future.
Show messages: All  1-2  3-7
