license key (box ) problem
All  1-4  5-8
2369.5 In reply to 2369.3
Hi jonah,
> Do you think i may hit that same problem again?
It's kind of hard to say - it sounds like your previous problem may have been some kind of bad installation of some system components.
I wouldn't think that installing Visual Studio should have any bad effect on MoI but if a system component does not get installed correctly all kinds of weird things can happen certainly...
If you run IE right now, what is the version number that is reported under Help/About? Maybe you got back to an IE7 install which then made MoI work.
It should normally be possible to uninstall the IE8 beta, so I'm not sure what happened in your case previously where you said you couldn't uninstall it? Note that its entry in the Add/Remove programs list is a bit different than what you might expect - instead of being under something like "Internet Explorer", look for it under "Windows Internet Explorer".
Also, probably a good idea to avoid installing beta OS components on your production system if possible! A beta of an individual specific program is certainly fine normally, but beta OS components have a lot more potential to mess things up.
2369.6
has this been fixed?
i tried re-installing MOI this afternoon and got into the same problem.
i'm running IE8 version 8.0.6001.18702
vince
2369.7 In reply to 2369.6
Hi Vince, the problem where the OK and Cancel buttons do not work properly when IE8 is installed is fixed in the 1.1 update.
You can download the update installer here:
http://moi3d.com/1.0/update/moi_v1_1_update.exe
If you run that updater, it will patch your 1.0 install to be version 1.1 that should now work properly with IE8.
Please let me know if you have any problems after doing the update.
2369.8 In reply to 2369.7
Ooops!
i should've looked for an update first before asking.
everything works fine, tnx Michael! :)
Show messages: All  1-4  5-8
