moi3d in 3d
All  1-4  5-6
2363.5 In reply to 2363.4
Hi Vincent,
> In the future, will be t-il possible to tilt axes a little as in Sketchup?
Maybe I will need some more explanation of what you want to do, but it is possible to tilt the camera to the left or right currently by going to Options / View / 3D view angles - that has a dialog that lets you enter specific angles for the 3D view orientation, such as an angle of elevation, a lateral angle orientation, and a tilt angle.
Does setting the tilt angle there give you what you need?
If not then I think I need some more details.
2363.6 In reply to 2363.5
Not a sketchup user but I think the c-plane will do the trick.
Effectively this 'tilts' the axis so that they are aligned to geometry rather than the standard global direction. Or as Michael puts it:
'CPlane tool (under the View palette) for setting the drawing plane. This allows you to align the drawing plane to more easily work on objects that are not aligned to the normal world axes. I'll try to post some more details about this later, it still is not quite completely finished yet.'
see this thread
http://moi3d.com/forum/messages.php?webtag=MOI&msg=1991.1
Is this what you mean, if so then it is already in the V2 beta.
Tony
Show messages: All  1-4  5-6
