Surface with specified number of points ?
 1  2-21  22-41  42-45
2350.42 In reply to 2350.41
Michael
I remember, back in the 1940s, when Algebra was added to our maths learning.
In the first three quarters of the year I was bottom of the class.
THEN it jelled!--and, at the end of the year, I was top of the class!
What was the "medium of understanding" that provided that "jell" factor?
Brian
ps More laughs about life!---I went on to enjoy playing around with Calculus.
BUT, the real laugh, in my very early 20s,---- in one of Aussies biggest companies,----
I was asked if I had an University education!
They asked, would you believe, because I regularly used a Slide Rule!
I AM NOT MAKING THAT UP!
2350.43 In reply to 2350.31
Hi Michael
Yep, I've spent quite a bit of time polymodelling so fully understand its strengths and weaknesses against nurbs.
As far as wanting to do control point manipulation goes the main reason for wanting to use it is the standard nurbs tools can create most of surfaces I want quickly and efficiently but there are just a couple of surfaces that control point manipulation is the ideal solution to avoid a quilted patchwork of surfaces that don't have continuity.
While being able to add additional points on surface exactly where you need them would be fantastic I think adding extra rows of points would be fine. Also having a type of specialised control point manipulation/tweaking tools would be good also. Anyway well wait to see what you come up with in future versions of MoI in this regard.
~Kevin~
2350.44 In reply to 2350.27
Indeed
2350.45 In reply to 2350.30
thanks Michael, I'm learning something every day here..
Show messages:  1  2-21  22-41  42-45
