Screen capture
All  1-8  9-10
2341.9 In reply to 2341.1
Hi Schbeurd, re: numeric palette going out of the window in screen captures -
In the next v2 beta there will be a new moi.ini switch that you can set:
[UI]
KeepFlyoutsInsideWindow=n
The default is =n which is the same as the current behavior. If you switch it to =y then it will keep those flyouts to be contained within the main window boundary which should help for that screencapture case that you mentioned.
But like Tony mentions, a pretty easy method to make it work now is to move the window to be near the edge of the monitor which will have a similar effect now.
2341.10 In reply to 2341.2
>>> Hi Bernard, haven't seen you here in the forum for quite a while! Hope things are going well with you.
Sorry that I couldn't respond earlier. Everything is going fine with me, thanks ! There's been some changes in my life during the last year and I don't have much spare time for 3D. But I work with MoI whenever possible... ;-) I'm also a regular lurker in the forum, just visiting as a guest.
Thanks for the fix for next version. Thanks also to Tony for the workaround. It does the job very well.
I'm waiting for the next updates of MoI and the object organization stuff ! You've done an amazing job so far.
Cya
Bernard (aka Schbeurd)
Show messages: All  1-8  9-10
