V2 beta Jan-19-2009 available now
 1-4  …  25-44  45-64  65-84  85-86
2333.65 In reply to 2333.63
Burr
Ahhhh!
There are different levels of brain weight users of MoI?
(And I will never sink a ship!)
Brian
Size: 4.4 KB, Downloaded: 43 times, Dimensions: 133x63px
2333.66 In reply to 2333.65
Hi Brian, well it seems like we've been through the same discussion on shortcut keys and scripting several times before, so I wanted to give you a very clear and thorough answer about what to expect in this area.
This situation will probably not be changing anytime soon, so if/when this comes up again I'll just refer back to that answer and we won't need to have a long drawn out discussion on it anymore.
there is somewhere a "big file" (10 megas) for make some test of speedy race?
2333.68 In reply to 2333.67
You could just use this one:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2333.4
And make 3 or 4 copies of it in the same file. (Use Ctrl+Drag)
2333.69 In reply to 2333.68
2333.70 In reply to 2333.69
A perfect description of what Michael does with his design and intent of MoI!!!!
Doesnt try to be like "all the other Apps"! Creates a whole new animal, better than the others!
2333.71 In reply to 2333.70
Agree!
And, not, also, my posts, perhaps, as well, relating to, ditto, in the fullnes of time, getting roundtuit, etc!!!
----having some mental (?!!) gymnastics?
Brian
Hey--it's all fun
2333.72 In reply to 2333.71
I suppose it's like the "CARRARA" app that allows a user to define new "Shaders" and "Materials" and then in the Carrara Beta Forum somone keeps asking the developer..."I saw you make this great Grey Brick Material that this guy needed for his wall model"..."Why do I need to be bothered with all this refraction, bumpmap, halo mumbo jumbo? Cant you just call it Grey Bricks and put it all on a menu? I mean, we're not all rocket scientists, so having to know all these settings to make a material seems odd to a normal user. Sure I see 3rd party developers making all kinds of materials, shaders and objects but how can I keep track of all these things? Cant you just INCLUDE them all in the application and let me decide which ones I want to use?
Back Handspring!
@Burr : Thx for the address of the test Robot
My result with a very old computer (6 years old)without multi core :)
Ati radeon 9200 (128 ram video) XP Amd 2600 1.91 GHZ
V1 = 35 seconds
v2 = 6 seconds
Not so bad ;) But I have something running in background so more results soon!
If I * 10 the robot moving in V1 is very hard
In V2 that works fine (thx Proxy)
EDITED: 22 Jan 2009 by PILOU
2333.74 In reply to 2333.73
That's a good timing improvement even on your older computer Pilou!
Yes, many of the optimizations will also help to speed meshing up quite a bit even on a single core CPU, it just gets magnified by a greater factor if you do have multi-core.
2333.75 In reply to 2333.74
just a little detail, but the first time you export a mesh I notice that divide larger than type is empty (when it's supposed
to be on 'curve' by default.
EDITED: 3 Dec 2015 by PAQ
2333.76 In reply to 2333.75
I think because thats now a MoI ini setting available to be set at what you like.
http://moi3d.com/forum/index.php?webtag=MOI&msg=2333.22
[EDIT]By the way, mine still came up curves! Maybe you added the new switches to your ini without setting it because my ini doesnt have all the new switches in it by default![EDIT]
2333.77 In reply to 2333.76
I take it all back! The second time I went to mesh, mine had disappeared too. And, all the switches are in my ini!
I'm loosing my mind.
2333.78 In reply to 2333.76
Hi Burr,
Should be something wrong with my .ini file, maybe because of all the beta installed.
I have delete the .ini file, and now it works as expected.
The old .ini has this value :
Angle=
DivideLargerThan=
DivideLargerThanApplyTo=
AvoidSmallerThan=
AspectRatioLimit=
Never add that myself.
2333.79 In reply to 2333.77
mm same here,
after one export, those lines are written in the .ini file :
Angle=
DivideLargerThan=
AvoidSmallerThan=
AspectRatioLimit=
The think is, dispite the fact angle is empty, moi chose 12 as default value.
However DivideLargerThanApplyTo= return an blank value, where I suppose 'curve' should showed by default ...
or something like that, my english is tired :P
2333.80 In reply to 2333.79
DivideLargerThanApplyTo=curved
Is the value to put there. What threw me was the case sensituve switch! In the Ui It's listed as "Curved" and that doesnt work. Checked the meshdialog file and saw it with lower case and it works.
2333.81 In reply to 2333.75
Hi PaQ,
Yup, definitely a bug, thanks for noticing and reporting it!
It was a bug introduced with that new stuff that allows for controlling the default mesh settings, I have fixed it up now for the next beta.
> Angle=
> DivideLargerThan=
> AvoidSmallerThan=
> AspectRatioLimit=
Yeah these will get added automatically to the .ini file after you do a mesh export.
They are supposed to be kind of "place holders" so you can more easily see where you can fill in default values if you want to set meshing defaults. But they are not supposed to be used if they are blank like they are initially.
Yup, that was the bug, it was treating a blank string type differently than a blank entry for something like a number value. There aren't really a whole lot of blank entries like this in the moi.ini so that's why it didn't really come up before.
Thanks for reporting it!
2333.82 In reply to 2333.3
The ScriptCopier_Jan_19_2009.exe look for Moi installed on C: On my system Moi is installed on D:.
Is there some parameter I could add when running to program to correct this?
Gaston
2333.83 In reply to 2333.82
Hi Gaston, there is no parameter to set on the script copier, but I will take a look at tuning it up to pop up a folder browser if it cannot find the default one.
2333.84 In reply to 2333.82
Hi Gaston, I have attached here a new version of the script copier which will open up a folder browser if it cannot find the programs (both v1 and the v2 beta) in their default locations.
Use the browser to pick the folder for MoI v1 and for the new v2 beta as necessary and it will then be able to copy any custom scripts or plugins over.
Show messages:  1-4  5-24  25-44  45-64  65-84  85-86
