V2 beta Jan-19-2009 available now
 1-11  12-31  32-51  52-71  72-86
2333.52 In reply to 2333.51
Hi Brian, I have updated that wiki page (http://moi3d.com/wiki/Shortcut_Keys) to also list the ways that you can use modifier keys with the mouse as well.
So that's now got a list of all the default shortcuts that ship with MoI, and also which keys do what when used with the mouse.
So I guess that is the kind of printout page that you were looking for?
But note that if you have defined a bunch of custom shortcut keys that are unique to your particular copy of MoI then those will not be listed there. If you want a printout of those, it may be a good idea to keep track of the ones that you add in your own text file somewhere.
2333.53
WOW!! Amazing Speedup for export!! Unbelievable!
Thanks!!
Ah, would be great to have ann print-option for the shortcut-table.
2333.54 In reply to 2333.53
Yes, That was Llama Mode! It's only fun to know... No Need.
MoI has its own path! It's not like other apps nor does it try to be. It's been stated, "if you want other apps, go use other apps!". MoI is blazing a new trail. Thats why people that have been using $70,000+ modeling apps are using MoI and loving it. It IS different.
It is what has stagnated the modeling software industry for so long. The idea that "I want/need it to do what my other app does" makes all apps the same....No innovation!
2333.55
Hi all,
I would like to help with the testing but I cant yet as I havnt bought a license yet :(
However I have a question regarding getting the most out of my computers power if anyone can please help.
I have an Intel Q6600 duel quad with 3 gigs of ram and running on Vista Home 32bit.
Does running on vista 32 mean Im notting getting the most out of my processor and ram and how will this effect working with MOI, should I upgrade to Vista 64 or windows 7 when it arrives?
EDITED: 22 Jan 2009 by STRAWBALE
2333.56 In reply to 2333.53
Hi B-W-Design,
> Thanks!!
You're welcome, I'm glad that it is working well for you!
> the shortcut-table.
The shortcuts are stored in the moi.ini file, which is just a text file so you can open it up and print it with any text editor.
The moi.ini file is located here (on XP, it is slightly different on Vista):
C:\Documents and Settings\ [your login name] \Application Data\Moi\moi.ini
Just open that file up in something like Notepad, and you can print it from there.
That file contains all your customized settings, if you only want to print just the shortcut keys, those are in a [Shortcut Keys] section, so you can edit out everything except for that section if you want a more compact printout.
That should work for getting a printout currently, please let me know if you have any problems!
I would like to improve the shortcut key editor in MoI in the future, but it tends to be a less frequently used area of the program. I mean that you only really go there to set up a shortcut key and it is not something that you normally need to do very frequently. So that tends to make it hard to prioritize development time in that area currently, since my time is limited I kind of need to place a higher priority on areas of the software that are used more frequently.
2333.57 In reply to 2333.55
Hi Jojo,
> it arrives?
Unless you are going to make very heavily detailed objects, you should be just fine with your current setup.
But if you are going to do something with a heavy amount of detail, then there is a setting that you will need to adjust in Windows in order for MoI to be able to see all your 3 GB of RAM.
The way 32-bit windows is set up by default, for every 32-bit program that is running, there is 2GB of address space set up for the program's use, and 2GB of address space that is reserved for the operating system's use for various hardware interfaces, file buffers, etc...
So with the default setup a regular program like MoI will not have your full 3GB visible to it, it only has 2GB visible to it. However 2GB is a pretty large amount of memory anyway so unless you are doing very heavily detailed stuff it is probably going to be fine just like that.
But there is an option where you can set up Windows so that it gives 3GB to programs and only reserves 1GB for the system. If you were to set that option then it would let MoI use all your 3GB of memory.
On XP this was called the /3GB switch, which you set in the boot.ini file:
http://msdn.microsoft.com/en-us/library/ms791558.aspx
In Vista there is no longer a boot.ini file, instead you use a utility called BCDEdit to set a boot option for it, some details here:
http://blogs.technet.com/brad_rutkowski/archive/2006/10/03/Hey-where-did-_2F00_3GB-go-in-Longhorn-and-Vista_3F00_.aspx
If you do use 64-bit windows instead of 32-bit windows then there is no need to set any switches, 64-bit windows is set up to make a full 4GB of address space available to programs like MoI without needing any special settings.
2333.58 In reply to 2333.57
Michael
Thanks for that earlier post. The subsequent ones by all are also great learning.
Just to clarify my thoughts---well, I hope!
I would envisage the average user not ever being involved with "scripts".
I would envisage all (note all) the scrips to be included in MoI as standard, with updates, or available (for the group of scripts) as an .exe file download.
I would envisage
1. RMB>Options Icon to provide a column of all the "Plugins" icons. This column would be narrow and movable/rotateable(Plugins selected by clicking the individual icon not keystroke?)
2. (say) MMB>Options Icon would provide a list of all short cuts.
Categorised?, including all Mouse actions, keyboard actions, or combinations of same.
All of the "scripts" would be listed, in plain english use titles, but left open for user allocation of key strokes.
Why will my brain not stop thinking?
Brian
Size: 233.8 KB, Downloaded: 19 times, Dimensions: 1248x1238px
Size: 66.2 KB, Downloaded: 36 times, Dimensions: 607x551px
2333.59 In reply to 2333.58
Hello,
On xp64, with 8 gig's, MoI stop meshing when reaching 3.3 ~ 3.4 mega ... just for info.
2333.60 In reply to 2333.58
Hi Brian, some good ideas there!
Unfortunately it is not necessarily an easy task for me to implement these ideas.
Just to be clear - it would take me many hours and probably even weeks worth of work to make the things that you want to happen here.
I'm not sure if you think that I can just push a button or something and make MoI work like this?
Unfortunately it doesn't really work like that at all, I have to pretty painstakingly write a lot of custom computer code to add and test functions to do these things.
It is hard to prioritize spending weeks of work on this particular area, since it only seems to cause problems for a very small number of people. The current system is kind of primitive but it is effective and basically it is something that you just go in and set up once and you're done, it is not an area of the software that people are using on a frequent basis. (the shortcut key editor I mean).
So it is not a very good trade-off currently to apply my limited amount of development time to this area rather than a more frequently used area.
I don't have super-human abilities, so it is not generally possible for me to work on many different areas all at the exact same time. So that means that the time I would spend working on this area would require me to not spend time on other more frequently used areas.
That's not a good payoff.
Because my time is limited, it can really be more effective if I try to apply my time towards areas that benefit more frequently used areas of the software, rather than rarely used areas.
I hope that explains the situation more clearly!
It is because of these reasons I have explained here that I do not expect to have major overhauls of this particular area of MoI anytime soon.
> in MoI as standard, <...>
Scripts are something that I generate sort of "on the fly" on an as-needed basis to help people do some particular task that they are asking about.
Like I've mentioned previously, I don't have psychic abilities, so it is not generally possible for me to foretell every single script that will be requested, which is basically what would be required for me to put them all into the software all in advance.
I'm kind of surprised that you get so frustrated when I post scripts to help people do a particular task. To me that seems like helping someone out with a bit of a custom logic specific to their particular needs. I guess from what you have said you would rather that I not help people out with their specific individual problems?
At any rate, I have now added some more information to the wiki page here:
which now contains all the information on mouse modifier keys as well, like what Ctrl+drag does, etc...
So that contains all the information about the default keyboard use that I know about, does that fulfill the need that you had about having a documentation page that covered keyboard shortcuts?
2333.61 In reply to 2333.59
Hi PaQ,
Yeah that is not unusual because the full address space to a program is not completely empty, other stuff such as the program code itself is in that same area.
Also the available address space can get diced up into sort of "fragments" where there isn't a big single block of address space available for something that needs a big single chunk.
Similarly if you have it at the default 32-bit 2Gb/2Gb split you will tend to actually max out more around 1.6 Gb of actual use.
2333.62 In reply to 2333.58
Brian,
I'd like to insert here.
Michaels last program "RHINO" has thousands of plugins written for it. It also allows scripting which has "hundreds of thousands" of scripts written for it.
These are applications that allow the user and other "developers" to customize things, sometimes for a "onetime thing only".
The software has A "Base" documentation, but if you want to delv into the realm of developer, it is unrealistic for the software company to try and control this.
As a beta tester, you'll see things fly by that arent documented yet (possibly ever). Something written only for "JIM" who need a light to come from a specific "Angle".
This isnt functionality of the software. Only the ability of it to be scripted.
Everything that is part of the "custom scripts" library that you use can be done with a simple default install of MoI! The scripts are just different way's it can be done (An infinate amount).
Are you going to add "Llama Mode" as a shortcut key??? I have! When my brain locks up and the juices stop flowing, I click Llama mode, LMAO, then contiue on to produce. Others may have no need for "Llama Mode".
2333.63 In reply to 2333.61
Michael
Sorry, you are missinterpreting my intents--I was hoping that last post would have helped make that clear.
I just add ideas into the pot.
I have so many,about ANYTHING,------ most will never be realised in my life time, or my grandchildrens.
Have you told Mr Obama that I am available for consultations?
Brian
2333.64 In reply to 2333.63
Quote: "Have you told Mr Obama that I am available for consultations?"
I tried to get through to his office but he was unavailable. He was busy documenting what he saw going on outside the whitehouse window!
6.00 am - dog barked.
7.26 am - michelle needed sugar handed to her for her coffee.
8.00 am - man on lawn whomb I dont know yet.
9.00 am - ignored call from some guy named Burr!
10.00 am - back to looking out the window.
11.00 am - ????
2333.65 In reply to 2333.63
Burr
Ahhhh!
There are different levels of brain weight users of MoI?
(And I will never sink a ship!)
Brian
Size: 4.4 KB, Downloaded: 43 times, Dimensions: 133x63px
2333.66 In reply to 2333.65
Hi Brian, well it seems like we've been through the same discussion on shortcut keys and scripting several times before, so I wanted to give you a very clear and thorough answer about what to expect in this area.
This situation will probably not be changing anytime soon, so if/when this comes up again I'll just refer back to that answer and we won't need to have a long drawn out discussion on it anymore.
there is somewhere a "big file" (10 megas) for make some test of speedy race?
2333.68 In reply to 2333.67
You could just use this one:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2333.4
And make 3 or 4 copies of it in the same file. (Use Ctrl+Drag)
2333.69 In reply to 2333.68
2333.70 In reply to 2333.69
A perfect description of what Michael does with his design and intent of MoI!!!!
Doesnt try to be like "all the other Apps"! Creates a whole new animal, better than the others!
2333.71 In reply to 2333.70
Agree!
And, not, also, my posts, perhaps, as well, relating to, ditto, in the fullnes of time, getting roundtuit, etc!!!
----having some mental (?!!) gymnastics?
Brian
Hey--it's all fun
Show messages:  1-11  12-31  32-51  52-71  72-86
