V2 beta Jan-19-2009 available now
 1-17  18-37  38-57  58-77  78-86
Wow, some great numbers there, thanks for posting them everybody!
That's really funny that now the stage of writing a large data set to disk can actually take longer than the mesh calculation itself!
This used to be a pretty painfully slow area, so it is great to have it tuned up to be so much better now...
2333.39 In reply to 2333.37
Hi Brian!
> The only uni file I can find is in the V1 folder. I presume that is the one?
Yeah that will be the one.
By default the moi.ini file will be created in your "Application Data" folder which will be here:
C:\Documents and Settings\ [your login name] \Application Data\Moi\moi.ini
However, you can optionally move the moi.ini file to be in the same folder as MoI.exe if you like - it is not set up like that by default because someone who does not have administrator privileges on their machine cannot write data to the "Program files" folder.
But if you move moi.ini to be in the same folder as moi.exe then it will check for it there first and use it from there if it finds it, it sounds like you have moved the file over there at some point in the past.
> I note some odd files that have been added--highlighted
> with a red line--is it ok to delete them?
Yeah, those are just previous entries in your "Recent files" list - the list of your previously opened files that pops up when you open up the Files menu. You can delete them if you want but if you delete anything before the first blank one (the first one with nothing after the = sign) then it will clear out that list to be blank when you start out MoI the next time.
Those entries are not really doing anything bad though, is there some special reason why you want to remove them?
> 1.Added option for LWO export---
> I can not see the default Modo setting there?
It will get added automatically the first time that you do an LWO export. Otherwise if it is not added yet you can add it in manually if you wish.
> 2. Updated Nurbs export----
> Does one actually type one of those options into the uni?
If you want to control that option then yes - again these will get added in with their default values to the moi.ini the first time that you do an export to either SAT, STEP, or IGES formats.
But they are only really of use when importing those files into applications that require data to be structured in a certain special way, probably you won't have any use for them yourself.
> 3. There are new options------values for meshing
> Is this relating to .obj saves?
These new options can be used to control the default values that are used when you save to a mesh format, which includes .obj format.
> Seems the same as before to me?
Yup, that is how it is supposed to be - only if you change those values will you see a difference. For example if you find that every single time you exported a mesh you wished that the angle parameter was set to 6 degrees, you can set that up now by setting Angle=6 in those options.
With that set, then the angle will have a value of 6 when that meshing dialog is initially displayed in a session.
If you do not have a special value that you need all the time for the default, then this setting will not be of any use to you specifically.
2333.40 In reply to 2333.39
Thanks Michael
Should also answer the several unasked questions also.
Brian
2333.41 In reply to 2333.40
Michael
Those "recent files" did not make sense!
I did another search and found the uni applicable to V2
"D:\Documents and Settings\Brian\Application Data\Moi"
Brian
2333.42 In reply to 2333.34
1.5GB PCIe x16 nVidia Quadro FX 5600 :)
The 7200 goes to the trash, replaced with the dead box's "quadro2 pro"
2333.43 In reply to 2333.42
Nomenclature for the "elderly"!
"Enabled making copies while in edit frame wheel mode, by holding down Ctrl before dragging the mouse."
I puzzled/experimented over this for ages and, hopefully, it means--
"New Shortcut to add to Shortcut key list
Ctrl -------- Allows drag copy of selected item"
Can I type this in on the MoI list or only on my desk printed version of the shortcuts list?
Brian
2333.44 In reply to 2333.43
You don't have to, this is a new feature that goes with the edit frame, it's not a script where you have to assign a shortcut to.
Michael gives a basic run down on how it works here > http://moi3d.com/forum/index.php?webtag=MOI&msg=2243.8
2333.45 In reply to 2333.43
Hey Brian,
It's not a new "Shortcut" key to add. It's functionallity in MoI's user interface that has been updated.
If you hold the cntrl key and click and drag ANYTHING, it will not move the object but move a new copy of the object. A quick "Copy and Paste" type thing.
Create a sphere, then ctrl+drag it somewhere! Presto!
What was being mentioned was that while in "Edit Frame-Wheel Rotate" Mode, THis functionallity wasnt working as expected and now it does again!.
2333.46 In reply to 2333.45
Danny/Burr
I think that what you are referring to is more the next point in the list "Enable grabbing---etc------"? (Which is LOVELY!)
I read the previous one, that I was referring to, "enabled making copies----" , as being a more universal "shortcut " that (also) applied in the wheel mode?
Dont' get old!
Brian
2333.47 In reply to 2333.46
Just to clarify.
I never knew that that Ctrl shortcut "copy" method applied in V1 (untill just now!)
It's not listed that I can find in any shortcut key list?
Is there another shortcut key list I should be aware of?
Help!
Brian
2333.48 In reply to 2333.47
Hey Brian,
Ctrl+Shift+Click the "Options Icon"! :)
2333.49 In reply to 2333.47
Actually it looks like that particular thing may have been missing from the documentation! I will try to fix that up for the v2 docs when I get a chance to tune them up.
But using Ctrl to drop copies is actually also used in some other areas that are covered in the v1 documentation, like in the docs for the Transform/Rotate command, which says:
"You can check the "Make copies" button or hold down the Ctrl key when clicking the last point to drop rotated copies of the object."
It's also mentioned under Transform/Scale as well.
This one is actually a mouse action + modifier key, which in MoI is categorized as a different type of action than a modifier key + keystroke, such as Ctrl+A for example.
Actions that are triggered by mouse actions do not show up in the Options / Shortcut keys list - that area only holds actions that are triggered fully by keystrokes and not mouse button clicking or dragging.
2333.50 In reply to 2333.49
Burr
Lost me--is that a Llama? (Did I need to know?)
Michael
"This one is actually a mouse action + modifier key, which in MoI is categorized as a different type of action than a modifier key + keystroke, such as Ctrl+A for example.
Actions that are triggered by mouse actions do not show up in the Options / Shortcut keys list - that area only holds actions that are triggered fully by keystrokes and not mouse button clicking or draggingl "
In every other app that I can think of, all options are listed in the main Shortcuts printouts.
With MoI there seem to be a lot of different "actions/proceedures/working principles" that seem at odds somewhat with those I have encountered elsewhere. And, in those areas, somewhat contrary to the basic beautiful principles of MoI workings.
Anyway, thanks for the efforts.
Brian
2333.51 In reply to 2333.50
In the future I can probably try to cook up a kind of "cheat sheet" like that to improve the documentation. Actually there is the start of one on the Wiki here:
http://moi3d.com/wiki/Shortcut_Keys
But that will probably be something different than the Shortcut key editor which is under Options / Shortcut keys currently.
That particular Shortcut key editor is meant only for editing shortcut keys, it's not really a "printout" documentation page or a place to edit mouse actions. It's meant to be a place just to set up your own customized keystroke actions.
Maybe that is one possible area of confusion? I mean that it sounds like you are expecting the place in MoI where you can define your own custom shortcuts to instead be a documentation page?
2333.52 In reply to 2333.51
Hi Brian, I have updated that wiki page (http://moi3d.com/wiki/Shortcut_Keys) to also list the ways that you can use modifier keys with the mouse as well.
So that's now got a list of all the default shortcuts that ship with MoI, and also which keys do what when used with the mouse.
So I guess that is the kind of printout page that you were looking for?
But note that if you have defined a bunch of custom shortcut keys that are unique to your particular copy of MoI then those will not be listed there. If you want a printout of those, it may be a good idea to keep track of the ones that you add in your own text file somewhere.
2333.53
WOW!! Amazing Speedup for export!! Unbelievable!
Thanks!!
Ah, would be great to have ann print-option for the shortcut-table.
2333.54 In reply to 2333.53
Yes, That was Llama Mode! It's only fun to know... No Need.
MoI has its own path! It's not like other apps nor does it try to be. It's been stated, "if you want other apps, go use other apps!". MoI is blazing a new trail. Thats why people that have been using $70,000+ modeling apps are using MoI and loving it. It IS different.
It is what has stagnated the modeling software industry for so long. The idea that "I want/need it to do what my other app does" makes all apps the same....No innovation!
2333.55
Hi all,
I would like to help with the testing but I cant yet as I havnt bought a license yet :(
However I have a question regarding getting the most out of my computers power if anyone can please help.
I have an Intel Q6600 duel quad with 3 gigs of ram and running on Vista Home 32bit.
Does running on vista 32 mean Im notting getting the most out of my processor and ram and how will this effect working with MOI, should I upgrade to Vista 64 or windows 7 when it arrives?
EDITED: 22 Jan 2009 by STRAWBALE
2333.56 In reply to 2333.53
Hi B-W-Design,
> Thanks!!
You're welcome, I'm glad that it is working well for you!
> the shortcut-table.
The shortcuts are stored in the moi.ini file, which is just a text file so you can open it up and print it with any text editor.
The moi.ini file is located here (on XP, it is slightly different on Vista):
Just open that file up in something like Notepad, and you can print it from there.
That file contains all your customized settings, if you only want to print just the shortcut keys, those are in a [Shortcut Keys] section, so you can edit out everything except for that section if you want a more compact printout.
That should work for getting a printout currently, please let me know if you have any problems!
I would like to improve the shortcut key editor in MoI in the future, but it tends to be a less frequently used area of the program. I mean that you only really go there to set up a shortcut key and it is not something that you normally need to do very frequently. So that tends to make it hard to prioritize development time in that area currently, since my time is limited I kind of need to place a higher priority on areas of the software that are used more frequently.
2333.57 In reply to 2333.55
Hi Jojo,
> it arrives?
Unless you are going to make very heavily detailed objects, you should be just fine with your current setup.
But if you are going to do something with a heavy amount of detail, then there is a setting that you will need to adjust in Windows in order for MoI to be able to see all your 3 GB of RAM.
The way 32-bit windows is set up by default, for every 32-bit program that is running, there is 2GB of address space set up for the program's use, and 2GB of address space that is reserved for the operating system's use for various hardware interfaces, file buffers, etc...
So with the default setup a regular program like MoI will not have your full 3GB visible to it, it only has 2GB visible to it. However 2GB is a pretty large amount of memory anyway so unless you are doing very heavily detailed stuff it is probably going to be fine just like that.
But there is an option where you can set up Windows so that it gives 3GB to programs and only reserves 1GB for the system. If you were to set that option then it would let MoI use all your 3GB of memory.
On XP this was called the /3GB switch, which you set in the boot.ini file:
http://msdn.microsoft.com/en-us/library/ms791558.aspx
In Vista there is no longer a boot.ini file, instead you use a utility called BCDEdit to set a boot option for it, some details here:
http://blogs.technet.com/brad_rutkowski/archive/2006/10/03/Hey-where-did-_2F00_3GB-go-in-Longhorn-and-Vista_3F00_.aspx
If you do use 64-bit windows instead of 32-bit windows then there is no need to set any switches, 64-bit windows is set up to make a full 4GB of address space available to programs like MoI without needing any special settings.
Show messages:  1-17  18-37  38-57  58-77  78-86
