V2 beta Jan-19-2009 available now
 1-6  7-26  27-46  47-66  67-86
2333.27 In reply to 2333.25
Hi Danny,
What is parallel view ?
Edit :
Hi Michael...
I am not clear about this :
"Added some script functions to access the camera point from a script, it is now possible to run this script on a keyboard shortcut to copy the camera and target points to the clipboard so you can find out where they are to set them in another program:
script:var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); moi.copyTextToClipboard( 'Camera=' + v.cameraPt.toString() + '\r\nTarget=' + v.targetPt.toString() );"
EDITED: 21 Jan 2009 by ANIS
2333.28 In reply to 2333.27
Formula-1 progress!!! Let us have a pit-stop.
George
2333.29
Great new stuff as always!!!
***Modeler Of Ideas***
2333.30
On Vista 64 Ultimate 6GB and IP7 2.6GHz a whopping 576 Solid pieces were converted into a 108MB .obj with 6456724 Polygons and 6467653 Point Count in less than 10 secs for screen display and saved in another 20-30 secs. More was not possible as that took 3.99GB Mem and a peppermint or polygon more would have caused a mess.
You're on to something Michael!!!
8)))
Rainer
2333.31 In reply to 2333.30
Maybe you must write 6 456 724 Polygons and 6 467 653 Point Count, more easy to understand the tremenduous numbers! :)
2333.32 In reply to 2333.31
wow, this is more than breathtaking:
MacPro, Dual Quadcore 2.8 Ghz, 6 Gig of Ram, Vista Business 64, Geforce 8800GT with 512 MB Ram:
MoI 1.0: 2:03 (1 608 626 Polys)
MoI 2.0, One Thread: 0:29 (1 816 449 Polys) (latest Beta)
MoI 2.0, No Thread Limit: 0:10
This was using a simpler mesh where I lowered the meshing angle to 1° to make it choke.
With a another mesh with normal settings (4°), it was 0:30 with MoI 1.0 but instantaneous with the latest Beta.
I have to dig out a more involved object for more tests.
Thank you so much, that makes exporting much more fun!
The other changes are also very welcome.
BTW. Scriptcopier doesn't work if one doesn't use the default path for MoI.
Cheers,
Thomas
2333.33 In reply to 2333.32
In the process of setting up the new crusher! Does the vid card have any impact here. If it does, I'll post some results too. If not, I think the pudding has already been eaten!
2333.34 In reply to 2333.33
Hi Burr,
Not particularly, except maybe in a kind of roundabout way.
One of the new things of the mesher is that it will display any objects that it has finished during the progress of the current meshing job, instead of only displaying the fully finished result only at the end like it used to.
If you have something really very old like your one Radeon 7200 card, then I guess it would be possible for that display part to take enough time to kind of steal the attention away from one of the CPU cores during the mesh calculation.
But if your video card is at all reasonable then it should not really be a factor.
Hopefully you are not initially setting up your new mega core box with that old Radeon 7200 , are you ?! :)
2333.35 In reply to 2333.26
Hi Tony,
> I didn't know about the vertex normals thing between
> Lightwave and modo as I only have modo.
Until very recently LightWave didn't support it, I think it is only supported in the newest LightWave release, I think version 9.5 ?
Unfortunately when they added support, it appears that they did not do it in a way that was compatible with Modo.
I can kind of understand how that happened because Modo implemented it in a somewhat strange way before that, where they expected the vertex normals to be in right-handed coordinates, while all the other coordinates in an .lwo file are in left-handed coordinates.
Anyway because of this kind of messed-up situation where each of them is expecting different kinds of coordinates for this same vertex normal data I have put in this switch in MoI.
> Which way did MoI do it before this update?
The Modo way, same as the new default.
So if you're using Modo you shouldn't need to mess with it.
2333.36 In reply to 2333.27
Hi Anis,
You were asking Danny, but I can give you an answer here - the parallel view is when you turn off perspective in the 3D viewport. It is also sometimes called an "orthographic" view. More details on wikipedia: http://en.wikipedia.org/wiki/Orthographic_projection_(geometry)
In MoI the option for this is under Options / View / 3D view projection: the choices are: Perspective or Parallel.
I'm pretty sure that you have used this before though, because didn't you like to set it up with the Parallel/orthographic type view to make it appear the same as SolidWorks?
Basically if you set up a keyboard shortcut with the script given there, when you execute that script it will copy the camera and target point locations to the clipboard. You can then paste them into a text editor to see the camera and target locations and enter those into another application if you want to synchronize the views with another app exactly.
Previously there wasn't any way to extract this camera information.
2333.37 In reply to 2333.35
Michael
Just a few questions about the list of V2 updates.
(Sorry if they seem completly dumb!)
The only uni file I can find is in the V1 folder. I presume that is the one?
I note some odd files that have been added--highlighted with a red line--is it ok to delete them?
Now a couple of questions which may help to answer some others by default.
1.Added option for LWO export---
I can not see the default Modo setting there?
2. Updated Nurbs export----
Does one actually type one of those options into the uni?
3. There are new options------values for meshing
Is this relating to .obj saves? Seems the same as before to me?
Brian
Size: 121.3 KB, Downloaded: 65 times, Dimensions: 1024x640px
Wow, some great numbers there, thanks for posting them everybody!
That's really funny that now the stage of writing a large data set to disk can actually take longer than the mesh calculation itself!
This used to be a pretty painfully slow area, so it is great to have it tuned up to be so much better now...
2333.39 In reply to 2333.37
Hi Brian!
Yeah that will be the one.
By default the moi.ini file will be created in your "Application Data" folder which will be here:
C:\Documents and Settings\ [your login name] \Application Data\Moi\moi.ini
However, you can optionally move the moi.ini file to be in the same folder as MoI.exe if you like - it is not set up like that by default because someone who does not have administrator privileges on their machine cannot write data to the "Program files" folder.
But if you move moi.ini to be in the same folder as moi.exe then it will check for it there first and use it from there if it finds it, it sounds like you have moved the file over there at some point in the past.
Yeah, those are just previous entries in your "Recent files" list - the list of your previously opened files that pops up when you open up the Files menu. You can delete them if you want but if you delete anything before the first blank one (the first one with nothing after the = sign) then it will clear out that list to be blank when you start out MoI the next time.
Those entries are not really doing anything bad though, is there some special reason why you want to remove them?
It will get added automatically the first time that you do an LWO export. Otherwise if it is not added yet you can add it in manually if you wish.
If you want to control that option then yes - again these will get added in with their default values to the moi.ini the first time that you do an export to either SAT, STEP, or IGES formats.
But they are only really of use when importing those files into applications that require data to be structured in a certain special way, probably you won't have any use for them yourself.
These new options can be used to control the default values that are used when you save to a mesh format, which includes .obj format.
Yup, that is how it is supposed to be - only if you change those values will you see a difference. For example if you find that every single time you exported a mesh you wished that the angle parameter was set to 6 degrees, you can set that up now by setting Angle=6 in those options.
With that set, then the angle will have a value of 6 when that meshing dialog is initially displayed in a session.
If you do not have a special value that you need all the time for the default, then this setting will not be of any use to you specifically.
2333.40 In reply to 2333.39
Thanks Michael
Should also answer the several unasked questions also.
Brian
2333.41 In reply to 2333.40
Michael
Those "recent files" did not make sense!
I did another search and found the uni applicable to V2
"D:\Documents and Settings\Brian\Application Data\Moi"
Brian
2333.42 In reply to 2333.34
1.5GB PCIe x16 nVidia Quadro FX 5600 :)
The 7200 goes to the trash, replaced with the dead box's "quadro2 pro"
2333.43 In reply to 2333.42
Nomenclature for the "elderly"!
"Enabled making copies while in edit frame wheel mode, by holding down Ctrl before dragging the mouse."
I puzzled/experimented over this for ages and, hopefully, it means--
"New Shortcut to add to Shortcut key list
Ctrl -------- Allows drag copy of selected item"
Can I type this in on the MoI list or only on my desk printed version of the shortcuts list?
Brian
2333.44 In reply to 2333.43
You don't have to, this is a new feature that goes with the edit frame, it's not a script where you have to assign a shortcut to.
Michael gives a basic run down on how it works here > http://moi3d.com/forum/index.php?webtag=MOI&msg=2243.8
2333.45 In reply to 2333.43
Hey Brian,
It's not a new "Shortcut" key to add. It's functionallity in MoI's user interface that has been updated.
If you hold the cntrl key and click and drag ANYTHING, it will not move the object but move a new copy of the object. A quick "Copy and Paste" type thing.
Create a sphere, then ctrl+drag it somewhere! Presto!
What was being mentioned was that while in "Edit Frame-Wheel Rotate" Mode, THis functionallity wasnt working as expected and now it does again!.
2333.46 In reply to 2333.45
Danny/Burr
I think that what you are referring to is more the next point in the list "Enable grabbing---etc------"? (Which is LOVELY!)
I read the previous one, that I was referring to, "enabled making copies----" , as being a more universal "shortcut " that (also) applied in the wheel mode?
Dont' get old!
Brian
Show messages:  1-6  7-26  27-46  47-66  67-86
