Whish: Boundary
All  1-10  11
2327.11 In reply to 2327.10
Hi Marc,
> I was wondering why didn't you fused "join" and
> "boolean union" in one command?
Well, the booleans are more intended to be used when objects need to be intersected and have some portions removed in order to finish the procedure.
Join on the other hand does not attempt to do any cutting, it only tries to glue things together at their existing endpoints (for curves) or edges (for surfaces).
This kind of makes Join in a certain sense more simple and it can possibly be more robust since it is more focused on just that task instead of also adding intersection calculations into the mix.
Show messages: All  1-10  11
