Shell is not working...
2325.1
I would like someone to confirm that it is not possible to shell the attached surface... I can't understand why...
Thanks...
***Modeling Of Ideas***
2325.2 In reply to 2325.1
Hi JTB, looks like a bug in the surface offset mechanism in the geometry library.
I'll take a look and see what if I can find out what is involved in the bug, but for the moment a quick workaround to get it finished now is to split it into 2 halves and use "ShrinkTrimmedSrf" (this has to be set up on a keyboard shortcut, there is not a button for it), then it can be shelled. I've attached a result.
2325.3 In reply to 2325.1
Hi JTB, this has been fixed up for the next v2 beta so that your original surface here will shell properly in the next v2 beta.
2325.4 In reply to 2325.3
and it's also working in v.1
/Lars
2325.5 In reply to 2325.4
Hmm that makes it a regression in some of the earlier updates to the geometry library that was applied near the beginning of v2.
For the next v2 beta I have another geometry library update (not quite as big as the one from earlier in v2, but several fixes) and fixing this regression seems to have been part of this new update.
