>>I've been overhauling the mesher quite a bit for this next release. These changes hve been primarily to increase speed of the export meshing, but there are also a few other bug fixes as well.
>>I'm still working on a couple of those bug fixes and then I'll try some tune-ups to the meshing UI then I'll be able to release a new beta with these improvements.
Although, as you say, technically the mesh is there, in reality it does have 'problems' rather than 'errors'. This means correcting it in the next app down the line. Especially if you want to use the MoI output as a basis for any sub-d work.
So anything you can do to reduce the problem areas would be great :-)
