Blend
All  1-2  3-10
2309.3 In reply to 2309.2
Ok I had expected that exist a special Tangent (G1, G2,....) or Curvature :)
Of course it's possible with another methods but with some steps ;)
2309.4 In reply to 2309.3
Those options for Blend are for how the Blend surface behaves where it touches the other edges, I mean at these areas here:
If I understand you correctly, you're asking for an option to have the "Blend" surface be G1 at those edges, but have a sharp crease in the middle of the surface instead?
Basically Blend will not do that job - Blend basically assumes that the blended surface itself is a smooth surface object, to make a creased object you will need to use other commands for that.
2309.5 In reply to 2309.3
Yes, just as many steps if there was a 90 deg blend function ;)
1.Plane
2.Rectangle
3.Boolean, Diff
2309.6 In reply to 2309.5
Looks like less than 30 seconds! :)
2309.7 In reply to 2309.6
:D
@Danny : you must begin from the 2 pieces given ;)
@Michael : No problem, that only funny that the Blend function gives near the solution in one click!
I love this construct one! :)
EDITED: 8 Jan 2009 by PILOU
2309.9 In reply to 2309.8
Pilou, I counted 6 clicks to do the blend method and 14 if you include the rectangles,
Yes I know, the family is out and I'm bored :)
2309.10 In reply to 2309.9
@Danny
When I say "One click" , it's the click of the call of the Blend Function :D
Alas that is not the "Angular Blend Function" (maybe in future version) only "Chamallow Blend" :)
Show messages: All  1-2  3-10
