molletta
All  1-5  6-9
2302.6
Hi Al. Actually i prefer the Vray image best, although i think the shadows are too hard. Looks like you are using a spotlight from nearly same direction as the camera? Spotlights have a tendency to blow out your image and give too hard shadows. So i would try with a rectangular light (or can VRay produce soft shadows from a spotlight?). And also move the light or camera position so both are not coming from same direction. Because you will not have nice shadows in the current setup, everything looks flat. You might try setting up the light and camera to be approx 120 degrees from each other (gives a little bit of backlighting effect), plus HDRI can give you a very quick and nice setup using just one light. I do this for quick shadow studies...
jonah
2302.7
Hi Michael and Friends
As Jonah writes and suggests
I have tried to improve the quality of Render in Vray, being inserted Lights and an Environment
they are still a beginner and this is the final result
what of it you say?
al
Size: 342.6 KB, Downloaded: 79 times, Dimensions: 765x573px
2302.8 In reply to 2302.7
Hi Al, I think that's definitely an improvement, it looks more realistic and less harsh. Looking great!
2302.9
Al, it looks really good! Excellent update... :)
jonah
Show messages: All  1-5  6-9
