Requests, lots of it.
 1-18  19-23
230.19 In reply to 230.16
> right mouse button + drag = rotate
> mouse wheel + clic + drag = pan
> Icone down Zoom + drag = Zoom in / out
You can also spin the scroll wheel to zoom in and out as well. If you're using a mouse, I think that is actually easier than using the zoom button. The zoom button is particularly useful when you're using a tablet which does not have a scroll wheel on it, or you can also use the zoom button to zoom in by a smaller increment than the scroll wheel by moving your mouse only a tiny bit - sometimes that can be useful.
Then in addition to this, you can also use Alt + left drag for rotate, Alt + shift + left drag for pan, and also shift + right drag for pan as well. These are all for compatability with other programs.
> Seems very more practical and speedy :)
In this case these additional options are more about being compatible with other programs (and people's habits).
230.20 In reply to 230.18
When the rule will broken, MoI will be at the Version 7 :)
Cool for the Zoom, I was too speedy so don't very good saw that ! Thx!
(so you have more clic free + drag horizontal & Vertical for another things :)
230.21
Hi Pilou, as Micheal replied already, these controls are just an habit.
It took me months to get used to it (when the scroll wheel wasn't working yet in Lightwave) and it's hard to let go :-)
My mouse also has a wheel which, ehm, snaps at certain degrees, so it's less accurate.
Michael, i'' try the hide trick. Sometimes the sollution is so simple eh? :-)
I'm abou to finish my model with the flipped normals (and some other strange behaviour). I'll post the file when it's done.
230.22 In reply to 230.21
Ok I understand :)
@Michael
Cool the trick of the "Points helpers" !
230.23 In reply to 230.21
Ok, this additional method of zooming will be available in the next beta release, which shouldn't be too much longer probably a couple of days.
Show messages:  1-18  19-23
