WIP - Hydraulic Connector
 1-8  9-28  29-39
2284.29 In reply to 2284.6
DannyT,
On behalf of Grendel, I can answer since I too work in the field.
Generally, bare stainless to ocean will be 316, 17-4, or 2205 duplex. Differences in grades particularly with 17-4 and duplex, and usually with 316 you would find 316L because the L designates a low carbon content for improved weldability. However reduced carbon can reduce strength but increase ductility/charpy characteristics.
- Jason
http://www.jasedesign.com http://www.nurbsandpolys.com http://www.cgpipeline.com
2284.30 In reply to 2284.29
Thanks Jason for the help, missed that. Answered part of the question but not the other ;P)
2284.31 In reply to 2284.29
Thanks for that answer Jason, actually forgot that I asked it so no sweat Grendel :)
The reason I asked then is that we use a lot of stainless in the line of work we do but we use Martensitic stainless steels mostly 420 series, machined then hardened to about 48 Rc, the problem lately is that we've had a few failures and we discovered it is due to intergranular corrosion.
Have any of you guys, Jason, Gredel, experienced this with the products you guys design being under the ocean and exposed to the salt.
2284.32 In reply to 2284.31
It's been a few years for me but a Marine Construction company I used to work for did a job where we had installed a fuel line under a pier using stainless hangers. The steel was speced out properly but there was something with 'WHERE" we got it that was the issue. Supposed to be the saltwater grade stuff and started corroding before we were done hanging it! Produced in a country where the spec stamp was penciled in I guess. Those company purchasing agents can make or break the best builders!
2284.33 In reply to 2284.32
Nice looking details on the connector.
2284.34
DannyT I have not used that material in any of our components. We stick with the 316 and Duplex for just about everything.
2284.35 In reply to 2284.34
400 series is not suitable for subsea or ocean, but it more used for surgical steel because of the hardening capability.
400 series does not contain nickel, and generally for stainless characteristics you are looking for combinations of chromium and nickel but with 400 series it is chromium that gives the corrosion resistance. Also, 300 series are not magnetic (a trade of austenitic steel).
What is it you are designing and the constraints? The other problem with 300 series SS is the fact that they require oxygen to work, that is to say they need oxygen for the surface oxide to protect the metal, without it the steel will corrode, so 300 series is susceptible to crevice corrosion.
For stainless steel informatin, you can try this site: http://www.ssina.com/index2.html
If you want, you can contact me at jason (at) jasedesign (dot) com
- Jason
2284.36
Thanks guys, interesting stuff !
Thanks for the chat invite Jason, but to chat to you about work......zzzzzzzz, I'd rather chat about what the weather is like down there and maybe modelling techniques :)
The original question was just out of curiosity.
2284.37 In reply to 2284.36
Danny, the invite was for whatever. Or catch me on NaP for modeling stuff.
- Jason
2284.38
Here is a 3d print of the connector using a Z-corp 650. This is straight from the machine and has not been sanded or dipped yet so the it's a little rough and the colors become brighter after dipping. The connector is about 7 inches tall, it's fun to have access to a machine for this stuff. Stuck my watch in their for scale.
EDITED: 21 May 2009 by GRENDEL
2284.39 In reply to 2284.38
Hi Grendel, thanks for posting the photo!
It is just so cool to see your model become materialized like this.
Show messages:  1-8  9-28  29-39
