WIP - Hydraulic Connector
 1-20  21-39
2284.1
Here is an example of a hydraulic connector used for subsea blow out preventer stacks. All the threads really added up the mesh time and time for boolean calculations but MOI pulled through in the end.
2284.2 In reply to 2284.1
Two choices for me!
!. Now-- this is something I should try to emulate---easy!
2. Am I kidding myself!
IF/When---I hope to show that YES! I can do that!
Brian
2284.3 In reply to 2284.1
Hi Grendel, it's a great looking final result! I'm glad that it finally completed, it must have crunched away on those threads for quite some time, those are rather brutal to process.
It will probably be quite a while before I can do anything to speed up the booleans, but there is a ridiculously huge speedup coming for mesh export in the next beta though.
2284.4
Give it hell Brian...everyone gets a little better trying something outside our comfort range.
"ridiculously huge" I love the sound of that. Some of my file sizes run at 90mb .3dm so I'm looking forward to that. Sometimes I'll wait 10-15 minutes for meshing on large assemblies so that is going to be great. Is it possible to multi-core the boolean calculations as well?
2284.5 In reply to 2284.4
It's theoretically possible... But difficult in practice unfortunately. It would require quite a few changes to the geometry library code, which creates a big problem for maitenance such as applying bug fixes or other updates from the core library.
I don't have that problem with the mesher since that part is all my own code.
There are also going to be some other big speed optimizations in the next beta for the dynamic feedback during transforms, like when you are moving the mouse around when dragging or mirroring objects, etc... This should also help out quite a lot when working on a heavy model.
You probably already know this, but just in case the other thing that can currently help a lot with heavier files is to go to Options / View / Meshing parameters, and set "Mesh angle" to something like 20 degrees, and uncheck "Add detail to inflections". That produces a much less dense display mesh which won't look quite as nice on the screen but it will conserve a whole bunch of memory and reduce display mesh calculation time.
The next beta will not quite have the display mesher working on multiple cores yet, only the file export mesher at first. But it won't take too much to get multi core going for the display meshing as well in a bit.
2284.6 In reply to 2284.1
Looks great Grendel !
What grade of stainless steel are you guys using for these subsea components ?
Just one thing about the threads, I find it unusual to have an assembly model showing detailed threads, especially if it is a working model. I work on large assemblies every day and we never show a detailed thread, it's always symbolic, so the bolt or screw/hole is just a plain shaft/hole with dashed circles at the top and bottom representing the thread, is this a visual thing for the customer ?
Just curious.
2284.7 In reply to 2284.6
Yes it's for a training and they prefer to see the physical threads, they look a lot better in an exploded view as well. I use Solidworks at work and I never model them either, just a callout or a bitmap representation.
2284.8
Michael ...
I sounds like the next beta may be soon ??? :)
Happy New Year.
eric
2284.9 In reply to 2284.7
Do either of you allow fly's on your wall? (Turn around and look... That would be me!!!)
2284.10 In reply to 2284.8
Hi Eric,
It's going well but still kind of in the middle of fixing up the meshing improvements, it will probably be another week or so before that is all complete.
Then I think I'll put out another beta with these performance improvements, but I won't have the object properties stuff finished up quite yet for this one. These performance improvements have taken a lot more time than I had thought so probably object colors which I had thought previously would be in this next beta actually won't be until the next one after.
2284.11 In reply to 2284.10
Hi Michael ...
Thanks for responding. I am excited about your progress with MoI. I can only imagine the amount of work it must take.
I am looking forward to object properties but am content to wait until that's ready.
Thanks for all your work and your patient and thorough help to all of us.
cheers,
eric
2284.12 In reply to 2284.11
Grendel
I started with a circle (which would be a sphere) and just let the mind run free on this preliminary sketch idea.
What great fun as the mind works!
The practical side of getting all the threading/exploded views of parts--wow--have I got some work ahead of me to refine.
PS the practicality of the idea is irrelevant!
Michael
Having all the sections Draw/Draw Solid etc open all at the one time at the right ( and with my Brian foot layout!) really, really is a high priority I suggest.
Hope it can be prioritised. I mumble/grumble here all the time!
Brian
2284.13 In reply to 2284.12
Actually the main priority during initial UI development was pretty much the complete reverse of that - to have a UI design that did not cause all things to be open simultaneously, since that tends to cause a lot of scalability problems.
By scalability I mean that there would not then be a natural way to add additional palettes in the future without having a big impact on the main UI.
In the future I would like to tune this up by having a kind of drag/drop UI arrangement type system, but unfortunately that will take quite a large amount of work to make that happen.
Because it will take a large amount of work to accomplish it, that unfortunately makes it very difficult to place it at a high priority, it would currently displace too many other much more frequently requested things.
That will probably be more like a v3 or even v4 type thing.
2284.14 In reply to 2284.13
Michael
You make me cry into my glass of Coopers! (V4---STRUTH!)--it's after noon--think I need to drown my sorrows with another stubby!
I think yours is a perspective from people who live on the upsidedown world from here---whereas , here, the day starts hours a head of you lot!
Ohhh!----the frustration!
Brian
Where are those tissues?
2284.15 In reply to 2284.14
Hi Brian, I know it's tough, sorry! ;)
The tricky part is that there are other priorities for the UI as well, for example to work well on many different resolution screens (not only just Brian's screen), and to be able to function well without forcing the need to scroll the UI up or down.
Having a panel where you sometimes need to do one click on a tab to activate a different palette is a whole lot better workflow than trying to scroll a big UI container up and down to find the right UI.
If MoI was designed to only run on just your monitor's resolution and not on any others, then it would be easier for me to have done some different things with the design and probably I would have separated things out by default (at least somewhat) more like you are talking about.
But I'm sorry - it is important for MoI to work well on a broader range of monitors, not only focused just on yours only! :)
The other thing you can do is edit the UI definition files - these are HTML files that are inside the \ui subfolder under MoI's main installation folder. These files control all the UI so if you edit them you can change the UI. If you really can't wait until v3 or v4 then that is an alternate way to get what you want right now.
2284.16 In reply to 2284.15
Maybe a survey of people who might, nowadays, use MoI on, less than , 17in Monitors?
Brian
NRN
2284.17 In reply to 2284.16
I guess that would include nearly all laptop users?
It's pretty hard to get accurate information in a survey. To get accurate information I would probably need to do something like build a reporting mechanism into MoI so it could automatically send data about machine configuration back to me, but a lot of people seem to not like having those kinds of reporting mechanisms in their software though.
2284.18 In reply to 2284.17
People who use MoI on less than a 15inch screens then?
The problem is, only, in modifying, very slightly, the size of the icons!--refer back to the earlier example I produced where it was done (roughly)
Brian
When you are convinced --make your point--I was taught that--also!
2284.19 In reply to 2284.17
"Having a panel where you sometimes need to do one click on a tab to activate a different palette is a whole lot better workflow than trying to scroll a big UI container up and down to find the right UI."
I would agree with this, its frustrating for me with other applications to have to scroll up and down palettes to see what is in them, seems kind of self defeating and disorientates the palette space.
The answer is to make a work space that is customizable, Sketchup is a very very good example of this, but I would agree that other things should have a higher priority, groups and layers for example!
I have the impression that you dont want to use right click menus but I think they will be almost essential to keep the organisation of palettes simple, no?
my demo runs out in a few days but I will be buying a copy very soon.
2284.20 In reply to 2284.18
Again, many laptops have smaller than 15 inch screens.
For example just a very quick survey of new DELL laptops here - I count 5 out of 11 models on that page have a screen of less than 15 inches in size.
Actually smaller sized laptops are currently one of the most popular types.
re: Icon size - you can actually change the size of the icons without tweaking the UI files, for that go to Options / General and use the UI size slider to scale the UI to your preference.
Show messages:  1-20  21-39
