swf file
All  1-3  4-7
2283.4 In reply to 2283.3
Hi Paolo,
> The only problem i have to solve is,how to make
> a clickable image, linking the .swf file
I think that normally using the <embed> code, the first frame of the .swf file should be displayed inside the Flash media player already, I don't think you have to set up a separate image which does need to be done for some other kinds of movie files like WMV for instance.
Please let me know if you have any problems and I will try to figure out what might not be working right.
2283.5 In reply to 2283.4
Sorry no result ,
I attached the HTML + .swf to the last message in
tread: 'question about networks', but only the link
seat.swf.html shows up which works well
EDITED: 2 Jan 2009 by PAOLOLOBBIA
2283.6 In reply to 2283.5
Hi Paolo, I'm not quite sure why the .swf does not show up in the attachment list, because it seems to be there...
But you will not want to upload the .html file if you want to make the video display directly inside of the message, instead you need to take the contents of that HTML file and paste that HTML code directly into the message editor window for your forum post.
For example if you open up seat.swf.html in notepad, you will see some HTML code. There is one line in there that starts with <EMBED> - copy that line and paste it directly into your message body, same as the text that you normally type in for a message (rather than as an attachment).
So for example in this case enter this text:
<EMBED src="http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=c040804e58f460551bf19b7673467a68&filename=seat.swf" quality=high bgcolor=#ffffff WIDTH="605" HEIGHT="595" NAME="seat.swf" ALIGN="" TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/go/getflashplayer">
But the only problem is that these flash videos can be rather large in size, and there is a limit of like 50MB for each person to upload attachments to the forum. If you do several videos you will pretty quickly fill up your entire allotment so you may need to upload them to some other video service instead.
Anyway, if you enter that text above into your message, it should make the flash player show up directly inside of your message post, like this:
2283.7 In reply to 2283.6
Now i understand it
Yes it's better to upload an animated GIF
Sorry for taking up much of your time,
now i turn back talking about Moi features
Show messages: All  1-3  4-7
