truncated icosahedron variant
All  1-10  11-16
2275.11 In reply to 2275.10
You have such a way with words Brian ;-).
P.s. the beautiful thing about vacuum distillation is that by using as a source of energy 60-70°C hot water flowing in a copper tube spiral inside the boiler the boiler itself can be made of plastic, e.g. the boatbuilders favorite .......GRP. By applying sufficient vacuum the boiling point could be kept around 30-40°C thus facilitating the transfer of heat/energy from the hot water to the fermented/boiling liquors.
Cheers!!!
......and Happy New Year!!!!
2275.12 In reply to 2275.11
I guess my sample will arrive in the post shortly.
Please include a sample done with other methods so I can truly compare!
Make my new year!
Brian
2275.13 In reply to 2275.11
Is there a tradition of using Geothermal for stills over there?
2275.14 In reply to 2275.13
Yes actually it is. The hot water just comes out of the tap, costs very little and by assuring enough surface area for efficient heat transfer into the fermented mash you can achieve high wattage/energy tranfer per time unit thus distilli large amounts in a relatively short time. Besides the use of hot water greatly reduces the fire hazard compared to using natural gas/propane or electricity.
EDITED: 29 Dec 2008 by TROUTCATCHER
2275.15 In reply to 2275.14
Brian .....do you want receive the moonshine filtered through activated charcoal or do you just prefer to consume the raw spirits without any rectification?
2275.16 In reply to 2275.15
Hmmmmnnn!
I thik nmly de inbult recti/rectall-? seeesnnt to coope-copy/cope--
"activeated" charcaal---from inurt to plysfool--whacco!
Brain
Show messages: All  1-10  11-16
