Need Advice Array object
All  1-2  3-11
2262.3 In reply to 2262.2
Sorry Michael....
There no hole on that image.
There are many sphere but array along surface.
edit : maybe in rhino its called array along UV ( I am not sure )
2262.4 In reply to 2262.3
Hi Anis - sorry, I didn't look close enough! I see now that they are little spheres.
MoI does not currently have an array command to replicate an object across a curved surface.
I think that Rhino does have a command to do that, so if you need to do that particular kind of shape I would recommend using Rhino for that currently.
2262.5 In reply to 2262.4
Hi Michael....
Yes I know, but I want to try with existing features :)
2262.6 In reply to 2262.3
One thing that you could try - get some curves below your surface:
Use Construct / Curve / Project to project them on to the surface:
Draw a sphere at the end:
Use Transform/Array/Curve to replicate it:
2262.7 In reply to 2262.6
Anis
I think you will see that this first approach needs a bit of finessing, BUT, I think the approach is right.
Hooray for Arrays!
Brian
PM me if you want the 3dm file.
EDITED: 31 Dec 2008 by BWTR
2262.8 In reply to 2262.6
Thanks Sir, I will try and post the progress later.... ;)
2262.9 In reply to 2262.8
I know its still far from perfect, but at least this method is working.
Size: 105.7 KB, Downloaded: 51 times, Dimensions: 646x544px
Size: 104.5 KB, Downloaded: 37 times, Dimensions: 756x508px
2262.10 In reply to 2262.9
Variations on the original theme.
Brian
2262.11 In reply to 2262.10
More variations--can not get to sleep so just fidling with various ideas for fun.
Used the projection of a spiral for the Array path.
Brian
Show messages: All  1-2  3-11
