Need Advice Array object
2262.1
2262.2 In reply to 2262.1
Hi Anis - that appears to be a vertical projection of a circle to make those holes.
So to do that, draw one circle, then select it, and use Transform/Array/Grid to replicate it into a grid pattern. Then select your base object, and use Boolean Difference, select the arrayed circles as the cutting objects and it should produce that result.
2262.3 In reply to 2262.2
Sorry Michael....
There no hole on that image.
There are many sphere but array along surface.
edit : maybe in rhino its called array along UV ( I am not sure )
2262.4 In reply to 2262.3
Hi Anis - sorry, I didn't look close enough! I see now that they are little spheres.
MoI does not currently have an array command to replicate an object across a curved surface.
I think that Rhino does have a command to do that, so if you need to do that particular kind of shape I would recommend using Rhino for that currently.
2262.5 In reply to 2262.4
Hi Michael....
Yes I know, but I want to try with existing features :)
2262.6 In reply to 2262.3
One thing that you could try - get some curves below your surface:
Use Construct / Curve / Project to project them on to the surface:
Draw a sphere at the end:
Use Transform/Array/Curve to replicate it:
2262.7 In reply to 2262.6
Anis
I think you will see that this first approach needs a bit of finessing, BUT, I think the approach is right.
Hooray for Arrays!
Brian
PM me if you want the 3dm file.
EDITED: 31 Dec 2008 by BWTR
2262.8 In reply to 2262.6
Thanks Sir, I will try and post the progress later.... ;)
2262.9 In reply to 2262.8
I know its still far from perfect, but at least this method is working.
Size: 105.7 KB, Downloaded: 51 times, Dimensions: 646x544px
Size: 104.5 KB, Downloaded: 37 times, Dimensions: 756x508px
2262.10 In reply to 2262.9
Variations on the original theme.
Brian
2262.11 In reply to 2262.10
More variations--can not get to sleep so just fidling with various ideas for fun.
Used the projection of a spiral for the Array path.
Brian
