MoI`s unit does not match to SketchUp`s unit?
All  1  2-6
2261.2 In reply to 2261.1
Hi fusion - there was a bug in the Sep-21 beta that did not transfer unit scales over to SketchUp properly, but this should be fixed in the newer Nov-21 beta release.
Can you please try updating to the newer beta to see if it solves the problem for you? The newer beta is available here: http://moi3d.com/beta.htm
Also there is an Update patch here for the Nov-21 beta which fixes a problem with mirroring, you'll probably want to apply that patch as well.
Please let me know if you are using the most recent beta and are still seeing this problem.
2261.3 In reply to 2261.2
Oh! Michael!Thanks for your enthusiastic !
I`ll try the patch immediately. hahahaha
2261.4 In reply to 2261.3
Hi Michael !
Nov-21_mirror_patch.zip can not fix that bug( MoI`s unit does not match to SketchUp`s unit).
MoI`s 1000mm equal to SketchUp`s 25400mm either!
2261.5 In reply to 2261.4
Hi fusion - just to be clear - there are 2 parts to the installation of the new version.
First, you need to download the Nov-21 version installer from here:
After you install that Nov-21 version, then actually your .skp export problem should be solved when running that new version.
Note - the new version is NOV-21 , you probably are currently running the older SEP-21 version which has the bug in it.
Then to make the Nov-21 version work better, it is good to apply the patch to it because that will fix a problem with the Mirror command.
But if you only applied the patch to your previous Sep-21 old beta install, then that will not solve the problem, you need to install the Nov-21 version to get the SKP fix part.
Please let me know if you did install the full Nov-21 version and still see this same problem. From your message it sounded like you only tried applying the patch and did not get the full install.
EDITED: 20 Dec 2008 by MICHAEL GIBSON
2261.6 In reply to 2261.5
OH i see :)
Thanks a lot! Michael
Show messages: All  1  2-6
