Off-topic CUDA
All  1-5  6-9
2256.6 In reply to 2256.5
Hi Paolo,
> PS: i got the link about CUDA from 3d-coat
I don't know the exact details, but I believe that 3d-coat needs to do some different kinds of processing on a very large quantity of very simple items (voxels).
I would think that he would use CUDA for different kinds of calculations or processing of the voxels, possibly including mesh generation, but it is not likely to be used for the actual direct rendering of polygons which is what you seem to be thinking of?
The kind of data that MoI uses - trimmed NURBS surfaces is not very similar to a voxel.
Unfortunately, something that applies well to voxel processing does not automatically apply easily to NURBS data processing.
2256.7
Great to here the multi-processor use for export meshing soon, thank you
2256.8 In reply to 2256.6
Ok Michael,
Thanks for your point of view,
2256.9 In reply to 2256.7
Hi Grendel,
You're welcome! It's looking good so far, there are some other parts to it in addition to the multi-core part - today I'll be working on some more general purpose optimizations that should help speed it up separate from that, and also the UI of the meshing dialog no longer freezes up while the meshing is being calculated. So you can do something like change a meshing parameter without needing to wait for the current mesh calculation to completely finish first. Now when you change a parameter, that will automatically cancel the current calculation in progress and start a new one.
It's a lot smoother operation for exporting, I was figuring that this area needed some attention pretty badly.
Show messages: All  1-5  6-9
