Off-topic CUDA
All  1-2  3-9
2256.3 In reply to 2256.2
I guess the use of Multi-core CPUs will benefit Boolean operations,
but i was more thinking about the meshing parameters
For example I draw the parts of the model steam engine which i put
i the Moi gallery
Normally i use a mesh angle of 5 degrees,showing a smooth surface
For the Drive chain i had to set it to 15 because i think the videocard
(Nvidia 7600gt) was suffering
So a more powerfull videocard is on my wishlist
Below the 3dm file
Size: 32.8 KB, Downloaded: 81 times, Dimensions: 315x627px
2256.4 In reply to 2256.3
Hi Paolo - actually CUDA though is not generally intended specifically for real-time rendering.
For standard real-time rendering the normal Direct3D programming interface that MoI already uses will handle that.
CUDA is for using the processing units on the video card for other kinds of computation tasks than standard rendering. Sort of like treating the video card as a special multi-core CPU that is good at handling a large number of simple parallel tasks.
Actually I would not normally recommend setting that below the default 10 degrees, as the default already generates a very dense mesh.
At 5 degrees it is going to create an extremely dense and high polygon display mesh.
I do plan on improving the display meshing for higher density scenes, I think I will probably try to manage the density more automatically and make the meshes become coarser more automatically as scene density increases. I may also be able to experiment with something like producing a coarse and light mesh initially and then produce some higher density ones in the background up to a certain allowance in density.
But generally CUDA is not going to solve the problem that you are talking about here, it is for something different. It is meant as a sort of alternative way to do general calculations rather than doing them on the CPU.
2256.5 In reply to 2256.4
Ok Michael,
Looking forward to it
PS: i got the link about CUDA from 3d-coat
http://3dbrush.kriska.hvosting.net/forum/index.php?showtopic=1412
2256.6 In reply to 2256.5
Hi Paolo,
I don't know the exact details, but I believe that 3d-coat needs to do some different kinds of processing on a very large quantity of very simple items (voxels).
I would think that he would use CUDA for different kinds of calculations or processing of the voxels, possibly including mesh generation, but it is not likely to be used for the actual direct rendering of polygons which is what you seem to be thinking of?
The kind of data that MoI uses - trimmed NURBS surfaces is not very similar to a voxel.
Unfortunately, something that applies well to voxel processing does not automatically apply easily to NURBS data processing.
2256.7
Great to here the multi-processor use for export meshing soon, thank you
2256.8 In reply to 2256.6
Ok Michael,
Thanks for your point of view,
2256.9 In reply to 2256.7
Hi Grendel,
You're welcome! It's looking good so far, there are some other parts to it in addition to the multi-core part - today I'll be working on some more general purpose optimizations that should help speed it up separate from that, and also the UI of the meshing dialog no longer freezes up while the meshing is being calculated. So you can do something like change a meshing parameter without needing to wait for the current mesh calculation to completely finish first. Now when you change a parameter, that will automatically cancel the current calculation in progress and start a new one.
It's a lot smoother operation for exporting, I was figuring that this area needed some attention pretty badly.
Show messages: All  1-2  3-9
