digi tablet
All  1-2  3-7
2252.3 In reply to 2252.1
Hi Andras,
I have a a Wacom bamboo fun with sliderpad and
4 buttons(programmable)and it works great with
artrage (with some exercise)
I use it in 3d-coat and Silo,but not in Moi
The simple version is the Wacom bamboo without
buttons,no eraser tip
It's pressure sensitive(512 levels)
I have read that the Intuos series have 1024 pressure levels
and can use an optional airbrush(not a real airbrush)
The next tabletpc i will buy is the HP Touchmart tx2 NotebookPC,
which you can use with a pen or your fingers(yes it cost)
2252.4 In reply to 2252.1
you have no money for a tablet but your prog Pro Concept is 1280 Euros without taxes !!! ;)
Else Wacom wacom wacom !
It's indestructible.
EDITED: 15 Dec 2008 by PILOU
2252.5
Wacom Intuos is the best - I used an A5 Intuos 1 for many years with no troubles. Upgraded to an A4 Intuos 3 last year. I also have an A5 Intuos 3 I use at work for everything from ProE through CorelDraw and just general Windows and MS Office stuff.
My first Wacom was the ArtPad with 512 pressure levels. Then I got an Intuos, the difference with 1024 pressure levels was very apparent. A colleague at work got a cheaper tablet and regretted it. He doesn't use it now.
So my advice is, if you are sure you will use the tablet then:
If you can afford it go for the Intuos. If you can't afford it, wait, keep saving and go for the Intuos. Or, buy cheaper software then go for an Inutos :-)
Tony
2252.6 In reply to 2252.4
Hello Pilou!
I just tryed out the Pro/Concept :) I checked and I decided to stay with my friend "Moi" :D.
2252.7 In reply to 2252.6
i have and have always use wacoms. my current wacom is the intous 3 A5 wide and its ideal. i also have a toshiba tablet laptop and its ok for small projects.so like the others have said go with wacom
www.max3d.org
Show messages: All  1-2  3-7
