fillet "sweep/lofted" solid (beta nov 21)
2248.1
It has been mentioned before about problems attempting to fillet edges where the surface seams are slightly mis-aligned, but I am seeing some problem even when the seam appears to be aligned.
Very simple example:-
Sweep the rect on the 2 circle rails.
Then attempt to fillet one of the edges, in this example the top inner edge
The maximum fillet is between 0.4 and 0.5
I then create the solid using closed loft
When I attempt to fillet the same edge, the maximum fillet is between 1.7 and 1.8
I then create the solid using extruded booleand cyliders
The maximum fillet on that same edge is <8 as expected.
If I now go back to the first solid made from sweep, seperate the solid, and rotate the top surface so the seams are no longer aligned, then rejoin
I can then fillet that edge as expected.
- Steve
EDITED: 3 Aug 2009 by MANZ
2248.2 In reply to 2248.1
Hi Steve - thanks for posting the examples!
Fillet has some problems on planar pieces that have seams or internal edges in them. That can be where there are multiple cut up co-planar bits joined together instead of one big plane, or in the case you show here where you've got a plane that is a kind of disc form with an internal seam.
In this case if you delete the top face, then select the object and use Construct/Planar to fill it with a simple trimmed plane that has no seam, then you can fillet up to the maximum amount of room.
For shapes like this where you're trying to sweep along a circular path, I would recommend using Revolve for that instead of either Sweep or Loft.
Revolve will produce a more simplified and precise result - the revolved result will fillet as expected without any extra work involved.
I'll take a look at the fillet failure in your example to see if there is anything simple that I can do to tune it up. But it is likely to be something that will need to wait until it gets fixed in the geometry library.
