Continuous surface
All  1-7  8-17
2237.8 In reply to 2237.7
With this particular curves Extrude with Set Path takes less smooth surfaces than Sweep with flat !
2237.9 In reply to 2237.8
Hi Pilou - in your case each piece of your "sine wave" like curve is a full 180 degree arc.
That's a lot more exaggerated of a bulge than a normal sine wave curve.
If you make the bulge of each of your pieces less extreme you will likely get a less bulgy result...
With that large amount of bulging, it would produce a very complex sweep as it tries to rotate the starting shape along each of those exaggerated bulges... That's why some kind of non-rotating method is needed.
You can kind of see what you are asking it to do if you do Transform/Array/Curve on it to make some copies along the curve that are rotated, you'll see a result like this:
You can kind of get an idea there of how your profile curve will swing around as it is rotated along the path, then it tries to produce a surface through that...
2237.10 In reply to 2237.9
Swinging indeed like smoke simulation! :)
2237.11 In reply to 2237.10
i was just playing with this for fun. you can truly sweep 1 segment and then array it.
edit: i think i might have done that with 'flat' sweep anyway. d'oh. :)
EDITED: 11 Dec 2008 by BODINI
2237.12 In reply to 2237.11
Yes it's the trick as show above ;)
2237.13 In reply to 2237.12
Works pretty good with the extrude-path. Here is sin wave "amp=4 length=20 cycle=10 points=5"
2237.14 In reply to 2237.13
Sorry. I just noticed your talkin about your "particular" curves. My bad.
Message 2237.15 deleted 11 Dec 2008 by BODINI
2237.16
Ack, this one broke flat sweep. Extrude path worked. Better stop now. :)
In fact seems nature of curves, & orientation are very sensitive!
this one works fine with Network! (5 seconds on a very old comput)
A small change and all works fine or not!
So a big training is necessary :)
Show messages: All  1-7  8-17
