Continuous surface
All  1  2-17
2237.2
Like this?
2237.3 In reply to 2237.2
Yes exactly!
How do you made that?
All my try were very slow so I stop the process!
I remake your example with a sweep in a second!
But mine take I don't know how many time!
OK That works! I was not enough patient! (and I have put the twist = Flat !
Seems don't work with the twist = free form !
EDITED: 11 Dec 2008 by PILOU
2237.4 In reply to 2237.3
"Calculating"... Zzzz....
2237.5 In reply to 2237.4
Is this simple approach not what is needed?
Brian
EDITED: 30 Dec 2008 by BWTR
2237.6 In reply to 2237.5
Thx for the effort Brian
Seems there are some sort of curves who don't arrive normaly to work with the Sweep
Michael will say to us why ;)
2237.7 In reply to 2237.6
Hi Pilou - sweep rotates the profile as it travels along the curve, I don't think that's what you want for this case.
I think the one that Grendel showed was using Extrude with the Set Path option instead. That sort of more drags the profile along the path without rotating it to be perpendicular to the path, it probably does what you need here.
2237.8 In reply to 2237.7
With this particular curves Extrude with Set Path takes less smooth surfaces than Sweep with flat !
2237.9 In reply to 2237.8
Hi Pilou - in your case each piece of your "sine wave" like curve is a full 180 degree arc.
That's a lot more exaggerated of a bulge than a normal sine wave curve.
If you make the bulge of each of your pieces less extreme you will likely get a less bulgy result...
With that large amount of bulging, it would produce a very complex sweep as it tries to rotate the starting shape along each of those exaggerated bulges... That's why some kind of non-rotating method is needed.
You can kind of see what you are asking it to do if you do Transform/Array/Curve on it to make some copies along the curve that are rotated, you'll see a result like this:
You can kind of get an idea there of how your profile curve will swing around as it is rotated along the path, then it tries to produce a surface through that...
2237.10 In reply to 2237.9
Swinging indeed like smoke simulation! :)
2237.11 In reply to 2237.10
i was just playing with this for fun. you can truly sweep 1 segment and then array it.
edit: i think i might have done that with 'flat' sweep anyway. d'oh. :)
EDITED: 11 Dec 2008 by BODINI
2237.12 In reply to 2237.11
Yes it's the trick as show above ;)
2237.13 In reply to 2237.12
Works pretty good with the extrude-path. Here is sin wave "amp=4 length=20 cycle=10 points=5"
2237.14 In reply to 2237.13
Sorry. I just noticed your talkin about your "particular" curves. My bad.
Message 2237.15 deleted 11 Dec 2008 by BODINI
2237.16
Ack, this one broke flat sweep. Extrude path worked. Better stop now. :)
In fact seems nature of curves, & orientation are very sensitive!
this one works fine with Network! (5 seconds on a very old comput)
A small change and all works fine or not!
So a big training is necessary :)
Show messages: All  1  2-17
