Pott(y)ery
 1-8  9-28  29-39
2230.29 In reply to 2230.28
Thanks mate--and to you
Brian
2230.30 In reply to 2230.29
Thanks to the inspiration from Grendel in the other thread.
Again, some great learning.
Brian
Size: 56 KB, Downloaded: 39 times, Dimensions: 800x500px
Size: 58.4 KB, Downloaded: 25 times, Dimensions: 800x500px
Size: 85.5 KB, Downloaded: 44 times, Dimensions: 800x600px
2230.31 In reply to 2230.30
I have a dream!
(Are you all aware of Heath Robinson ?)
http://images.google.com/images?q=Heath+Robinson&rls=com.microsoft:en-au&oe=UTF-8&um=1&ie=UTF-8&sa=X&oi=image_result_group&resnum=4&ct=title
I have NO IDEA where this is going to lead but here is a first bit---
Our 55th wedding aniversary last Friday-----please have sympathy for my better half!
Brian
Size: 126.6 KB, Downloaded: 45 times, Dimensions: 1024x640px
2230.32 In reply to 2230.31
This is a (wierd?) next stage idea development--well--maybe-- in the fullness of time!
M0I had some great difficulties with the file sizes! (next V2 beta will fix?)---so I went into Carrara to develop.
Quite mad-- I know---!!!
Brian
Size: 64 KB, Downloaded: 46 times, Dimensions: 640x480px
2230.33 In reply to 2230.32
There are some updates for the next beta to handle some parts of large file sizes better, like performing transformations like dragging or mirroring large objects is much smoother on large objects now.
But if you are making a zillion copies of an object, that probably still won't work very well yet, you really need a program that does "instances" to do the best job of a tremendous number of copied objects. MoI still will not handle that part yet.
2230.34 In reply to 2230.33
Michael
Sorry if that sounded as a "complaint"!
From what you have been saying, MoI will better handle larger file sizes in next up dates, but, even so, I would still not expect it to compare with, say, what can happen in the likes of Carrara with it's "Replicator"!--for a start
Maybe, I was highlighting, again, that Carrara is a great companion app to MoI!
Finger poised for the next beta
Brian
2230.35 In reply to 2230.34
Hi Brian, didn't sound like a complaint, sounded more like a feature request to me! :)
There are quite a few different features to add to improve large file handling, so it's kind of something that will improve in chunks as certain things get added over time.
This next beta actually has 2 pretty significant pieces though - one is that improved speed for transformation feedback, so things like mirroring or dragging large complex objects is smoother.
Then the other is a major speed increase in mesh export speed, including taking advantage of multiple CPU-cores for meshing.
These improvements should already help out quite a bit for heavier files, but they are kind of more oriented towards working on one big complex object though, making a huge number of copies of an object is kind of a different area.
To make a high number of duplicated objects work better requires a different function called "instances" where copies of an object just basically record a marker for where to place another duplicate of an existing base object, rather than having fully duplicate objects. I'm not sure exactly when I'll get a chance to work on this area, it may be a while before this one happens. Until then a tool that has support for this kind of function will definitely be a good companion to use for this particular kind of purpose.
2230.36 In reply to 2230.35
Michael
Apps like Carrara can do those special things allready, it seems superflous to take up time in MoI's development that is not really necessary.
Some of the developments you plan don't excite me particullarly--not my current field of "modelling"?--but thats me!
As I think you aim, MoI is Special!--in it's area of expertise--it does not need to be made just another, complicated/ ho hum universal app.
Horses for cources?
Brian
Size: 42.4 KB, Downloaded: 32 times, Dimensions: 640x480px
2230.37 In reply to 2230.36
Is this showing any signs of sanity yet?
Brian
Size: 87 KB, Downloaded: 53 times, Dimensions: 640x480px
2230.38 In reply to 2230.37
Time for bed.
Brian
Size: 52.9 KB, Downloaded: 28 times, Dimensions: 640x480px
2230.39 In reply to 2230.38
I have just done a complete remake of the Scout Belt Buckle I posted on the other thread.
Probably close to being "correct"
The file size is about 3MB if anyone wants.
Brian
(Carrara render)
Size: 54.7 KB, Downloaded: 30 times, Dimensions: 640x480px
Show messages:  1-8  9-28  29-39
