How to draw diamond shape?
All  1-9  10-20
2227.10 In reply to 2227.5
These are the technical specifications of
a briliant cut diamond
Sorry it's written in Dutch
Size: 234 KB, Downloaded: 161 times, Dimensions: 317x1068px
Size: 211.5 KB, Downloaded: 159 times, Dimensions: 968x1143px
2227.11 In reply to 2227.10
Thanks all.
So much stuff in my To Do folder!
Brian
2227.12 In reply to 2227.5
Hey Brian, give it a metallic material, make it glow hott white and enter it into the 50's SciFi contest! LOL
Great alien saucer if I say so myself :-P
-Will
2227.13 In reply to 2227.1
Here's a 3DM file of a Diamond from one of the Rhino jewellery Plugin's I've got.
I'm also including a picture that contains the angles & proportions that are used for cutting an "Ideal Diamond".
Here's a link that might also prove useful.
http://www.preciousmetals.com.au/
Hope all of this is of help, Colin
Size: 16.5 KB, Downloaded: 116 times, Dimensions: 360x227px
2227.14 In reply to 2227.13
Thanks Will and Colin.
Just where could rendering alternatives end up?
Brian
EDITED: 31 Dec 2008 by BWTR
2227.15
here is a another cool source with 3d models of real gemstones including .3DM, as well as jewelry related information
http://www.3dlapidary.com/HTML/Collections.htm
2227.16 In reply to 2227.15
Yannada (Michael?)
Those 3DM Rhino files (3dlapidary) do not open in MoI?
(OK in Carrara)
Any explanations?
Brian
2227.17 In reply to 2227.16
That usually means that the objects inside of the 3DM file were polygon mesh objects and not NURBS objects.
There are various different kinds of things that can be stored in a 3DM file such as NURBS objects, polygon meshes, spotlights, dimensions, etc....
MoI only deals with NURBS and single point objects, it will skip any polygon mesh objects that are in the file and I think those particular files only have those kinds of objects in them.
Those polygon mesh objects can be converted in Rhino into NURBS objects by using the meshtonurb command on them. That conversion will allow MoI to read in those objects.
2227.18
oops sorry for the incontinence caused, I should know that...
2227.19 In reply to 2227.18
Well one needs something to grumble about I guess!
Brian
2227.20
If you want to do accurate jewel stone modeling you need a cut sheet. It will give you the proper angle/dimensions for a particular cut of precious stone.
See this post for pics and an example file.
http://moi3d.com/forum/index.php?webtag=MOI&msg=623.34
Show messages: All  1-9  10-20
