Sweep can be use for ?
All  1-14  15-19
2226.15 In reply to 2226.14
Hi Paolo, yeah although they can sometimes use the same set of curves, Network and Sweep calculate their result differently.
Network is actually more related to Loft, and actually internally the calculation does do 2 Lofts, one through the U curves and another through the V curves, then those surfaces are combined together to produce the final result. It's kind of more of an averaging process between all curves.
Sweep is more like sliding a rigid frame along the rail curves.
2226.16 In reply to 2226.15
Thanks for the reply,
On my work i used this to design part of
a ring in Rhino,and it so much easier to do
in Moi
To bad i didn't convince my Boss to buy
a licence
2226.17
Michael - can you tell us if/when we will have auto chamfer of ridgid shapes i.e. a rectangle sweeped around another rectangle with the corners joined up? Just would be easier than offsetting the spline and using 2 rails each time. Some cool sweep examples here :-)
2226.18 In reply to 2226.17
Hi rhodesy,
I expect to have that for v2 but I probably won't get a chance to work on it until after the group/object management stuff is complete.
2226.19 In reply to 2226.18
I had to experiment with the Anis post 2226.6.
OK, it's very rough, but the potentials, NOT using polys, I find very interesting.
I can not get over how things seem so easy/logical to do in MoI as compared with Rhino/Amapi/Hexagon/Silo/LW/XSI
NOW,--- if only my MoI 3DM files thumbnailed!
Brian
EDITED: 31 Dec 2008 by BWTR
Show messages: All  1-14  15-19
