Scale Array ?
2224.1
Hi Michael....
I forgot on how to use scale array.
Would you like to make video or some image to explain to me...
2224.2 In reply to 2224.1
Hi Anis - you have to include a single point object (draw it with Draw curve / Move / Point ) which will be used as the center of each scaling operation.
Check out the original post for some more instructions and an illustration here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=275.109
Draw any objets + one point
Select all : apply a classical Array (even with Array on Curve)
Select all (Objects + Points) except the curve (if Array Curve)
Alt + S (if you have this ShortCut)= Scale Array : enter your regulates
That all ;)
EDITED: 6 Dec 2008 by PILOU
2224.4 In reply to 2224.3
Hi Michael, Pilou...
Still confuse :(
A little video will be helpful...
2224.5 In reply to 2224.4
Here are my steps :
2224.6 In reply to 2224.5
Hi Anis,
Complete the array first, by pressing 'Done', then apply the scale array and choose only the array objects not the path curve.
2224.7 In reply to 2224.6
Yes you have don't follow my little tut words to words ;)
A very funny and powerful script!
2224.8 In reply to 2224.6
H Danny,
I have tried but :(, look at video below :
2224.9 In reply to 2224.8
Anis, pick all the array circles.
2224.10 In reply to 2224.9
Hi Danny,
Thanks your last tips work :)
Hi All,
Attached is video tutorial on how to use ScaleArray command.
Hope this make more clear...
Message 2224.11 deleted 7 Dec 2008 by PAOLOLOBBIA
2224.12 In reply to 2224.10
Cool video but at the end you should erase the curve for complete general result ;)
Any "Spirograph drawing" in 2D can be made with this crazzy script ;)
http://www.samstoybox.com/toys/Spirograph.html
EDITED: 7 Dec 2008 by PILOU
2224.13 In reply to 2224.12
This stuff is also associated with the Bracelet thread and a SketchUp building thread.
Just showing the various uses of the scale array etc.
Brian
EDITED: 30 Dec 2008 by BWTR
2224.14 In reply to 2224.12
I was so in love with Spirograph!
