instances wish
All  1-13  14-17
2217.14 In reply to 2217.13
Maybe you could allow only uniform scaling and rotation on instances, the changes made anywhere this way would be the same, except for the rotation and scale factor.
For external instances it could work by dragging a file, another button in the 'drag and drop' window would invite you to choose the instance option.
Just some exploratory thoughts, I realize how things can get pretty complex!
Marcus Welby
2217.15 In reply to 2217.14
Hi Marcus, those are definitely some good ideas!
That could possibly be a good way as an alternative shortcut to help set it up.
But I don't think it would work as the _only_ way to set up a file linkage, I mean what if you wanted to see what the linkages were in a file that you opened up from someone else?
What if you wanted to change the linkage to a different file name or remove it?
To fully support these kinds of tasks it really needs some kind of managment mechanism with its own dialogs, etc...
Taken all together, it is quite a large amount of work... I'm not really at a good place yet to dig into it yet.
But it is great to hear different ideas! I just wanted to explain that it may be a while yet before I am able to act on any of those.
2217.16 In reply to 2217.15
I guess maybe we'll have to see how you are implimenting the v2 management system before we can make suggestions on how to encorporate instances. I've got a few ideas but it really depends on how the layers and colours system is going to work. Any more sneak peaks into your plans for this michael?
2217.17 In reply to 2217.16
Hi Rob, well it is still kind of a work in progress.
There is some info on the direction and general ideas in these previous posts:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1944.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=2127.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=2150.5
Show messages: All  1-13  14-17
