Gridon top of objects?...
All  1-6  7-13
2212.7 In reply to 2212.4
> If there was a way to simply adjust the object opacity -
> even an INI file option, that would be helpful.
No, there's not currently anything for that. Transparency is not actually a completely easy thing to add, video hardware does not actually handle it automatically you have to render things in a particular way (ordered by depth always) to make it work.
> BTW, is there a post that explains the use of the
> construction plane a bit further?
No, not really. I was meaning to do it but it hasn't happened yet.
There's sort of 2 ways that you can do it - there is an automatic alignment that happens when you place the origin point on an object.
If that did not produce what you want, you an manually align it by grabbing and dragging axis lines individually. You can normally get an alignment by placing 2 axis lines. After you place the first axis line, when you pick the next line it will be constrained to rotate around the first axis line that you picked.
If you've got an example where it did not automatically get placed how you wanted, can you please post it? Maybe I can fix the automatic alignment to work better, or also it would be a good test case to show how to do the manual placement.
Silly idea ;)
Why not another grids? Spheric, Hyperbolic, logarithmic etc...?
Can be useful!
I believe that I have not seen that anywhere, and seems to me that is not a big deal?
How works the snaping in general? does calculates are remade each time for a point of a grid screen's grid or there some points in memory?
EDITED: 3 Dec 2008 by PILOU
2212.9 In reply to 2212.8
Hi Pilou, it's a cool idea!
No, unfortunately quite a big deal once you add together all the user interface work that would be required to set all the parameters for all these various kinds of grids...
It also could be problematic for the time involved in drawing all the very many curves that would be needed to display such grids. For example when you viewed it at a pretty slanted angle in the 3D view the display would have to draw quite a lot of curves just for the grid.
> each time for a point of a grid screen or there some points in memory?
For rectangular grid snap it is calculated each time but that is a very simple calculation, basically a rounding to the nearest grid value.
Hyperbolic/logarithmic would probably be a lot more difficult to calculate I suppose.
So quite a lot of difficulties actually!
2212.10 In reply to 2212.9
thx
so I put it in the wish list for distant future version :)
2212.11 In reply to 2212.5
Here's a screenshot of the selectionsphere for the techies in the forum.
I suppose this is what changes with the snap settings!???
2212.12 In reply to 2212.11
Hi Burr, yeah that's kind of interesting when you can see the radius visualized like that.
There is actually a separate radius for those markers in the moi.ini:
[Drawing Aids]
ObjectSnapShowMarkers=y
ObjectSnapMarkerOpacity=80
ObjectSnapMarkerDisplayRadius=100
In the options dialog when you set Options / Snap / Snap radius - that controls the screen distance that your mouse needs to be within for a snap point to actually activate.
Those "markers" are set to display at a larger radius than that to help you kind of see what snaps are available in that general area, to help you move closer to them to target them if you want.
The reason for this kind of 2-pronged system is that it tends to cause problems setting the actual "activate snap" radius to a larger value because you end up snapping to everything and can't place a point more freely in space very easily anymore.
2212.13 In reply to 2212.12
That makes sense, You look and see something, go in for the kill...It becomes available as A snap...."SNAP" you catch your target.
A perfectly stylized flow! ooops, one to many beers!
Good night.
Show messages: All  1-6  7-13
