Another Helix/Sweep bug?
2203.1
See the pic. Weird results with a sweep on a 50 turn over 10" helix (0.200 pitch). A circle about 0.150 or smaller will not sweep the helix, but a circle bigger than about 0.150 will.
I had a look at http://moi3d.com/forum/messages.php?webtag=MOI&msg=1263.2 and others, but this isnt a 6 turner.
-Nick
edit: forgot to attach files.
Size: 74.8 KB, Downloaded: 240 times, Dimensions: 479x875px
2203.2 In reply to 2203.1
Hi Nick, thanks for posting the bug and the example file!
After some examination, it looks like another instance of the underlying problem that causes that 6-turner bug as well.
This one is rather amazing though that the conditions so perfectly align to make the bug happen, since it does check in a lot more than 7 places along the helix curve. But it just works out that all the places that it happens to check are all in tolerance with that unwanted result surface. Here you can see the different stations that are checked in yellow:
In theory you should be able to work around the bug by making an additional copy of the profile up vertically 0.2 units (the helix pitch) to force a tolerance check of the shape at that additional profile location. But that does not work properly right now since it hits a recursion limit due to the pretty long rail. I've raised the recursion limit for the next v2 beta so that this one (with the 2nd added profile) will work properly in the next v2 beta.
The main bug should get fixed when I get a chance to work on sweep some more, which I think won't happen until after the scene browser stuff is complete. Anything that messes with the tolerance checking I need to test rather carefully so that I don't cause the sweeper to get way slower than it already is.
Thanks for the report, I have now got it bundled for testing along with some other sweep stuff.
2203.3 In reply to 2203.2
Seems only with "Flat" also. Mine sweeps with freeform.???
2203.4 In reply to 2203.3
Yeah, flat style is what triggers the problem.
