Sweep ignoring corners?
All  1-4  5-8
2183.5 In reply to 2183.1
Offset the centerline of your sweep to the inside (so there are 2 lines). Then use those 2 rails for the sweep to get mitered corners.
EDITED: 27 Nov 2008 by BODINI
Size: 104.1 KB, Downloaded: 76 times, Dimensions: 729x481px
2183.6
Yes this one has urk'd me in the past also!
But as already mentioned, a 2-rail sweep will get you what you originally expected.
I didn't know about the micro bevel getting this to work as well?!
-Will
2183.7
The 2 rail option seems to be the best. The micro fillet forces the sweep to turn a corner, but it's not a clean result - it goes through itself.
2183.8 In reply to 2183.7
Also not mitered as I think that was the intended result.
Show messages: All  1-4  5-8
