Sweep ignoring corners?
All  1  2-8
2183.2 In reply to 2183.1
Just adding the very smallest Fillet radius to the corners of the sweep line will fix it.
O.01 for example.
Brian
EDITED: 31 Dec 2008 by BWTR
2183.3 In reply to 2183.1
I think the sweep is not liking extreme corners. Without a file its hard to tell but it looks like you tried to sweep a circle around a square???
You could choose your square first and run fillet and give a very small radius like .125 or something, then the sweep will act as you expect.
2183.4 In reply to 2183.1
Hi Duke - currently 1-rail sweep will not do the mitered corners that I think you're looking for there. It is something that I expect to be adding in later on in v2 though.
Check out here for an alternate approach for now:
http://moi3d.com/forum/index.php?webtag=MOI&msg=428.12
2183.5 In reply to 2183.1
Offset the centerline of your sweep to the inside (so there are 2 lines). Then use those 2 rails for the sweep to get mitered corners.
EDITED: 27 Nov 2008 by BODINI
Size: 104.1 KB, Downloaded: 76 times, Dimensions: 729x481px
2183.6
Yes this one has urk'd me in the past also!
But as already mentioned, a 2-rail sweep will get you what you originally expected.
I didn't know about the micro bevel getting this to work as well?!
-Will
2183.7
The 2 rail option seems to be the best. The micro fillet forces the sweep to turn a corner, but it's not a clean result - it goes through itself.
2183.8 In reply to 2183.7
Also not mitered as I think that was the intended result.
Show messages: All  1  2-8
