How would I model this glass?
 1-3  4-23  24-29
2179.4
Gave a it a shot, quick model actually, good exercise with nice results.
I did exactly as per Anis' and Michaels method except did each piece individually then Boolean union.
The main revolved glass cut outs, were Boolean diff with a surface that I mucked around with by manipulating the sweep curves until I got what I thought was ok. (History is my friend) :)
It might not be exact proportions I just eyed it off the screen, rendered in Hypershot.
Model attached if interested.
EDITED: 27 Mar 2009 by DANTAS
2179.5 In reply to 2179.4
I, Leon phelps, finally has something to put my Courvoisier into before I swoon the ladies!
(Sorry, another american tv ref)
2179.6 In reply to 2179.4
Seems there is a little error ;)
2179.7 In reply to 2179.6
Good pick up, I didn't notice that, as I said it was a quick job I wasn't too fussed.
Oh yeah, you just reminded me, when I tried to do that blend with G1 the whole top part of the glass did a disappearing act.
2179.8 In reply to 2179.5
Hey 'Leon' luv the hair do :D
2179.9
Well i'm convinced. I modelled it in Max with polys, but its just so much cleaner and natural to do it with Nurbs. Although if I were to do it tomorrow it would be with MoI because I just bought it 5 minutes ago!
2179.10 In reply to 2179.9
My little bit of fun with the idea!
Brian
EDITED: 31 Dec 2008 by BWTR
2179.11 In reply to 2179.3
Hi Michael
i have forgot the name of the software you are using to make the gif tutorial/explanation, can you mention that again?
it have been mentioned in the forum before, but i could'nt find it, and it seems pretty good..
anyway, i really enjoy to follow the development of Moi, and am impressed about the effort and skills form your side.
best regards
// Leif
2179.12
Danny, how long did that Hypershot render take?
2179.13
The most popular screen recording package is TechSmith's Camtasia and Snagit.
Somewhat pricey but well worth it when attempting to show software behavior to developers, etc.
-Will
2179.14 In reply to 2179.13
or you could try jing which is also produced by techsmith ( which is free) also a while ago they had a free version of camtasia which i downloaded, dont know if they are still doing it though
www.max3d.org
2179.15 In reply to 2179.14
Free : camstudio.org
2179.17 In reply to 2179.15
free and also quite interesting:
http://www.screencast-o-matic.com/
needs java though..
marco
2179.18 In reply to 2179.4
DannyT - Thanks for sharing your model.
I also made a Hypershot render using their Kitchen HDRI. This is their low resolution version of the HDRI, so the background environment is not a sharp as it should be.
Using my quad-core PC, the "real time" image was instantaneous (and could not see a difference compared to the final render). I increased the quality settings quite a bit for the final render (not that it made any noticeable difference) and produced the attached render in 40 seconds. With default quality settings the final render took 6 seconds.
Ed
Marysville, WA
EDITED: 25 Nov 2008 by EDDYF
Size: 59.1 KB, Downloaded: 94 times, Dimensions: 451x450px
2179.19 In reply to 2179.8
I keep it that way for the "ladies"!
2179.20 In reply to 2179.6
Yeah it looks like a bug in the filleter when trying to handle sharp corners touching a smooth surface right at the seam area of the smooth surface.
Unfortunately that's not an easy area of code to work on fixing up, it will probably be a while before that bug can get fixed.
In the meantime since that object is symmetrical it looks like there are other fillet areas that were created correctly that can be rotated and trimmed into place to fix that one little spot if you want to correct the error.
It's awfully hard to see that little spot in the rendered model though.
2179.21 In reply to 2179.11
Hi Leif,
I'm using Camtasia Studio v5 (http://www.techsmith.com/) , as I've gotten more used to it, it has gradually become more natural to use it to explain things that take several steps. (rather than a longer sequence of static screenshots I mean).
Thanks very much!
2179.22 In reply to 2179.12
Hi TwinSnakes,
Same as ed, seconds, the picture you see there is is only a screen shot.
ed, your welcome!
2179.23 In reply to 2179.22
Here is my quick render in Carrara6Pro. Both HDRI and Caustics. 40secs.
Think I have the glass a fraction thick?
Brian
Show messages:  1-3  4-23  24-29
