Feature Request: Multiple Inset Tool
All  1-2  3-5
2178.3 In reply to 2178.1
Hi LOTRJ, it's a good idea!
The only problem is that Offset is pretty full of a lot of options already, I'm kind of hesitant to more to the heap right now.
Actually when you mentioned making it work like directional array, that got me thinking me thinking that it should actually be possible to use the current directional array tool to solve the problem.
The way you can do it is to create a "Point" object which is available under Draw curve / More / Point.
That lets you create a single point which can be used for snapping on to.
So if you create a starting point object on the inner circle like this:
Then you can use Array Dir to create the spacing that you want, like so:
Then all the spacing is set up, you can use each of those points as a snap target for Offset (with Through point mode) or for drawing a circle with the Circle command.
2178.4 In reply to 2178.2
> Scale Array not working in the latest beta it seems though!
Is it possible that you haven't installed it yet into the new beta?
Custom commands that you have installed in an old beta do not come over automatically to a newly installed beta, that may be the problem that you're running into.
I'd like to do something to improve this in the future, but I have not had a chance to work on that yet.
2178.5
Perhaps it doesn't have to be extra settings in the current inset tool.
I was thinking more along the lines of a separate 'inset array' tool to go with the other array tools.
Thanks for showing me that point reference method, I hadn't thought of that.
Show messages: All  1-2  3-5
