Bended plate how would you do this?
 1-6  7-26  27-36
2173.7 In reply to 2173.6
I have not looked at Michaels post because I get great enjoyment in puzzling out solutions.
This approach, if different to Michaels, could only have been done in the way shown with the current V2 beta version I think.
I hope the jpeg explains the proceedure clearly.
Brian
EDITED: 31 Dec 2008 by BWTR
2173.8
Maybe I am just being dumb here but is there anyway to just draw a extruded rectangle cut it in the middle and bend it some degrees? Like we will doing with a actual metal strap?
2173.9 In reply to 2173.8
Hi Wagurto.
I do not know if this what you are looking for, not exact but vaguely looks like it me!.
This is my way of approaching the problem. I created the wire frame and then used the network tool.
Then I used the shell tool to finish off.
Happy modelling.
Malc.
2173.10 In reply to 2173.8
This method was easy.
I drew a plane, then copy/paste, then rotate the 2nd plane to get angle. Join, fillet as desired, seperate, show points and move bottom 2 points to desired angle, then zoom at fillet area use object snap to reattach edges, join.
2173.11 In reply to 2173.8
The combined bend/twist needs in this idea are the problems I think.
It is the apparent simplicity of the idea that is intruiging.
I doubt if, even in a poly programme, that this one would be easy.
Anyone have any comments?
It's good fun learning!
The attached may more clearly example the arc on the box face in the 3D workspace.
Brian
2173.12 In reply to 2173.8
Hi wagurto,
Rhino3D has a bend function
You can download a Demo from this site:http://www.rhino3d.com/download.htm
I don't use the 'bend function',because it's difficult to handle
In the picture there is my solution in Moi3d
Size: 62.1 KB, Downloaded: 79 times, Dimensions: 1078x849px
2173.13 In reply to 2173.12
I needed to confirm that I could add volume.
Brian
2173.14 In reply to 2173.8
Hi Wagurto,
Nope - there is no function like that in MoI. In MoI if you want to make a bent shape you usually draw it with the bend built into your drawing. There are a variety of different approaches that will work, you can see a lot of different ideas covered in the thread here.
That recording that I put up earlier was a real-time recording, so that takes about 1 minute of time to draw something like that.
You do have to use a combination of tools to do that, but you should generally expect that when you want to make a shape that has elements of it that bend around in 3D, that it will take some combination of tools to make that happen.
If there was a different special tool for each kind of possible custom shape that you wanted to make, the UI would be completely overflowing with special tools...
I do actually want to add a Bend tool in the future, but there are some technical difficulties with having that kind of tool work on the kind of geometry that MoI uses. So it will probably take a while before that happens.
Maybe I'm not understanding what you are trying to do - is there a particular reason why you need a tool to do this faster than 1 minute of drawing time? Are you making a whole bunch of these or something like that?
You may want to check out a sheet metal focused application rather than MoI, it would possibly be set up for doing those kinds of specialized things more easily.
EDITED: 24 Nov 2008 by MICHAEL GIBSON
2173.15 In reply to 2173.14
Michael.
I have tried ot your very elegant method. Just sweet.
Have you a similar elegant way to add thickness?
(My effort is very messy)
Brian
2173.16 In reply to 2173.14
Hi folks, I've come up with this solution, hope it helps.
Dan
"The darker the night, the closer the dawn."
(Buddhist Proverb)
2173.17 In reply to 2173.15
Yeah I just used Shell for that same as it looks like you are doing there.
That generates a result with constant thickness but yeah the joint part is maybe not quite right.
One way you can get more control over that is to build 2 sheets for the top and bottom parts, and then Loft do fill in the side walls. That gives you more complete control over the shaping.
2173.18
Michael thank for the reply and I am not complaing about your solution. The thing is that I am trying to model a logo that contains several of those twist and bends and have to have some precise measurements and doing it your way for a newbe sounds a lot of work. My suggestion is maybe from a complete ignorant point of view. This is what i am trying to accomplish.
Thank you again.
Size: 64 KB, Downloaded: 89 times, Dimensions: 1137x459px
2173.19 In reply to 2173.18
Hi Wagurto, your suggestion is a good one, but unfortunately there are technical difficulties that make it difficult to create the computer code for a bend-type modification tool on the kinds of objects that MoI works on.
So that's why you have to construct the bent object out of individual pieces similar along the lines of what is shown above.
Do any of the above techniques give you a way to build your object? Or are you still stuck?
You basically need to build it piece by piece, using one of these techniques. I mean build a straight part, build a bent connector part, boolean or join pieces together, and it looks like you want to then put fillets on it at the end to round the corners.
You can probably build one segment and duplicate it.
There just isn't any method available in MoI to start with one long strip and bend it around to get that result, sorry! It has to be built in pieces.
2173.20 In reply to 2173.19
Michael
Sorry to be dragging this on. Following your method-----
I can not get the original to Shell?
I am quite proud of the outer layer I produced as you suggested but I can neither get an effective loft between the two or an edge sweep?
Brian
2173.21 In reply to 2173.20
Looks like there are some micro-sized folds in your surface:
That kind of situation where a surface folds back over on top of itself in a small area really throws a monkey wrench into shelling or offsetting, because the surface normal very suddenly shifts to the opposite side in those spots.
It looks like your original curves have that kind of folded over spot in them.
That folded over area is probably also giving a problem for sweeping - for lofting are you possibly trying to Loft the 2 large curves together all in one operation?
One of those curves is made up of 3 segments, and the other is made up of 8 segments - MoI doesn't really know how to best match up differing numbers of segments like this and will just average the entire shapes together, which probably does not result in what you want.
To get better results with lofting that case, you'll need to break things into their segments by using Edit/Separate, then loft it in smaller pieces (like in this case in 4 different Lofts) so that you can force the segment matching to be what you want.
Hope this helps!
2173.22 In reply to 2173.21
Michael---you can probably see the dark mushroom cloud over my place from where you are!
LOVE the rotate gizmos etc in the other thread!
Brian
2173.23 In reply to 2173.18
I got some cool results by sweeping a helix then squishing it down.
Its somewhat different shape than what you show, but if you were allowed the creative, then its fast and looks great. Maybe for future creations. Works less for the W V A thing but more for a similar effect quikly!
2173.24 In reply to 2173.23
Burr, that one really has the most natural kind of look to it!
Yeah slightly different than the official target design since the sections are not straight, but it also seems like that same thing gives it a much more natural wrapping look to it as well...
2173.25 In reply to 2173.12
Whoa!
I did not know that blend works on curves, I surely learned something today!
That's the problem, Moi makes me feel like I don't "need" to read the manual!
Marc
2173.26
Perhaps this will help it's just a sweep of a rectangle along two lines blended with tangential option
EDITED: 25 Nov 2008 by RAFAELLO
Size: 26.2 KB, Downloaded: 49 times, Dimensions: 504x581px
Show messages:  1-6  7-26  27-36
