MoIV2 Beta Nov-21-2008 Questions
 1-13  14-33  34-53  54-73  74-86
2168.14 In reply to 2168.8
Hi Marco,
> Color object and style ????
> and other feature ????
I'm still working on these, they won't be finished up until the next beta.
Sorry it takes a while to finish things, but it is better in the long run for me to work on these features carefully and thoughtfully so that they end up working well, rather than just slapping things together as quickly as possible.
If I did it as quick as possible you would have something now but it would have a poor UI and it would be buggy and crash a lot, you probably don't want that!
Suggestion: when object's name is too long line is cut in 2 parts
Why not make 2 lines : one for the object's name, one for the quality ?
so quality can be writed without abbreviation! 8 Closed curves
2168.16 In reply to 2168.15
Michael,
What is the correct script for to put in the command column to create a shortcut for CPlane in the new 11-21 beta? The word "CPlane" itself raises an error.
Thanks!
--Lewis
2168.17 In reply to 2168.16
Hi Lewis - yeah cplane is slightly different than a regular command (mostly because you can run it while you are still running inside of another command). To set it up on a keyboard shortcut use this:
script:moi.view.setCPlaneInteractive();
If you want to set up a key for resetting the cplane to world, use this:
script:moi.view.resetCPlane();
It's also possible to set up some shortcuts to switch to a Front or Right CPlane if you want:
Set CPlane to Front plane:
script:moi.view.setCPlane( moi.vectorMath.createFrontFrame() );
Set CPlane to Right plane:
script:moi.view.setCPlane( moi.vectorMath.createRightFrame() );
2168.18 In reply to 2168.17
Michael
Firstly, a great fealing working with the new beta. Things seem to do as expected rather than frequently having to say, damn, I forgot you have to do this the X way!
However, an odidty (not a problem)
When changing the Z dimension on this grouped item, this strange result?
Brian
PS I am regularly running out of uploading space. If the lists of my loads were dated it would be much easier to make quick deletions that would, in this instance, enabled the loading of the 3dm file.
EDITED: 30 Dec 2008 by BWTR
2168.19 In reply to 2168.18
Hi Brian, I'm glad the new beta is working for you!
It has several of the problems that you reported fixed - that shape you had that would not window select should now work fine, and that problem with trying to draw a planar curve over top of a sphere should now be solved as well.
It looks like it was probably 2 separate objects, and only one of them was selected?
When you change the size, it only makes a change on the selected objects. If something was not selected, it won't change.
If it is a different problem than that, could you please post a .3dm model file of the shape so I can check it out and see if it is a bug that should be fixed? You can also e-mail a file to me directly at moi@moi3d.com instead of posting it.
Yeah, that would be better definitely.
Unfortunately there is not currently any option in the forum software to do that, I would have to quit writing MoI code for a while and work on some forum code instead to make that happen.
2168.20 In reply to 2168.19
Thanks Michael.
I though I had all the items selected!
Have made space for this download.
Brian
EDITED: 27 Dec 2008 by BWTR
2168.21 In reply to 2168.20
Hi Brian, thanks for posting the file!
Are there any particular steps that I should follow to see the problem?
Over here it seems to work as expected if I select those objects and change the z value, it works like this:
Are you seeing something different than that?
2168.22 In reply to 2168.17
Thanks, Michael. That CPlane script works fine.
--Lewis
2168.23 In reply to 2168.9
Hi Lewis,
You wrote:
> But I would also like to see the ability to set new
> construction planes and save them,
This is definitely in the cards, but probably not until after I get the "scene tree browser" type thing working.
I think that browser panel (discussed some in this other thread) will be a kind of "one stop shopping" area for listed / named entities of various sorts, and if it works out how I'm kind of thinking it would probably be best to list things like saved cplanes there rather than trying to make a special UI for managing the list of them.
One other thing that you may be interested in, is that MoI v2 has some functions to be able to draw directly on to any planar surface using it as a temporary construction plane. The nice thing about that is that it kicks in if you just click your points on the surface while in the 3D view, you don't have to do any extra cplane setup/restore/etc... steps. So that may help reduce the need to set a cplane for some common situations. Some examples on that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1621.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=1621.21
http://moi3d.com/forum/index.php?webtag=MOI&msg=1621.27
2168.24 In reply to 2168.22
Michael
HopeI can explain this.
In the first instance, I did a sellection of all the items.
Then I did the Z make smaller.
That was fine, except, it left a separate, copy (well, actually the original?), unsized, of the wiggly bit,---- where it was originally!
As I said it is not a problem as I can delete this "copy" bit---it was just that the "oddity" seemed worthwhile reporting.
Tis a strange world!
Brian
2168.25 In reply to 2168.24
Hi Brian, I think I understand - the file you posted is the result of _after_ the problem occured?
Unfortunately what really helps me is to see the file _before_ the problem, so that I can try to repeat the steps over here and watch the problem actually happen directly rather than just seeing the aftermath... :)
So if you happen to notice something weird, it can be a big help if you undo, and then save. That way there is more of a chance that the problem can be repeated. Sometimes it is tough to remember that, but if that is possible it is easier for me to debug.
2168.26 In reply to 2168.10
> Trivial question :)
> When I name
> Sphere = ob1
> Cube = ob2
> Selection ob1 + ob2 and name it = ob3
Just to clarify - when you select multiple objects and set the name, you are not creating a group, it is doing the same thing as if you selected each object individually and assigned them all the same name.
So on your 3rd step there there are no longer any names of "Sphere" or "Cube" present, they have been overwritten when you entered the new value of "ob3".
> Now when I select the Sphere only, Sphere's name is ob3,
> Cube's name only selected is ob3
Yes - since you set both of their names to ob3 in your 3rd step.
> How clear the group selection? (ungroup)
There was no group made... So nothing to ungroup, if you want to clear the selection click in an empty area or push escape.
> And seems the Undo to the start keeps the all group name ob3!
Yeah, undo is not working right with the properties that needs to be fixed.
> if I select all so ob3, when I clear the the name ob3
> Sphere and cube become Unnamed !!! seems must be ob1 and ob2 ;)
You then assigned them an empty name which is displayed in the UI as "unnamed".
It is an interesting idea to make a group by assigning the same name to a multiple selection, but I think that may cause some problems. I'm generally intending for grouping to work with a different mechanism than that, which will be part of the scene browser tree thing.
The name is just a descriptive tag that you can set on an object, assigning a name does not make it into a group.
> PS there is not yet a list ?...(arborescence)...
Not yet, Styles and colors are going to come first, then the scene tree after that.
There is still a lot of work left to do for this area, as I've mentioned before it will take a few betas before it is all complete.
Does that all make sense? Please let me know if any of that doesn't seem right.
2168.27 In reply to 2168.26
Observation: MoI objects 'name' does not transfer to Rhino's 'name', which I'm only pointing out because I thought opennurbs was a structured file format (and therefore 'a' is 'a').
Betas looking good though! :-)
2168.28 In reply to 2168.11
Hi Burr,
> Just so I'm clear. I'm not sure which number is the "actual" size.
> So if I were to create a 1 inch square to machine, Would it be the
> new "size" option or the "custom distance tool".
> I guess I just dont understand when this number can be different
> and why.
The size that is reported is the size of the object's bounding box in the world coordinate system (unless you set a custom cplane in which case it is in the cplane coordinate system - setting a custom cplane basically re-orients the grid to a different position and rotation).
But a bounding box around an object can have different sizes depending on the orientation of the object.
Here's an illustration - here I've got a 5 x 5 square, which is aligned with the x and y axes. The x and y axis bounding box around this is the same exact size as the square itself, and you can see that the size readout says 5 x 5:
Now let's say we take that square and rotate it, the bounding information will change, even though we did not scale the square:
That's because a rotated square has a larger bounding box than the axis-aligned square, here I've drawn the bounding box to illustrate:
The sides of that original 5x5 square are still the exact same length as before, but the bounds of it are different.
Which one is most important to you (the length of the square's edge versus its bounding size) may be different for different kinds of purposes, but I would think that when you were machining you would probably consider your stock to be a world aligned piece and you'd be interested in the overall size of the object in that stock rather than the size of the rotated edge? If so then the current size readout should be the right thing for that.
Actually that would help me to know what you expect to see when the 5x5 square rotates - would you always want to see the size as 5x5? Or would you like to see the bounding size which changes as the object has different rotations?
EDIT:
Just to try and clarify further, this is where the size is coming from with the rotated square:
EDITED: 22 Nov 2008 by MICHAEL GIBSON
2168.29 In reply to 2168.13
Hi Burr,
> Seems "Undo" doesnt work on the object properties.
Yup, I forgot about that part!
It doesn't fall under the umbrella of the regular automatic undo handling because it doesn't actually change any geometry.
But it should not be too difficult to fix that up.
> Object name doesnt persist and desist with multiple group
> namings and changes. more like layers. "Styles" will probably
> acheive what we want here but of course I'm just chatting and
> will wait for Michaels response with you!
Yeah setting the name just sets a label on an object, and if you have multiple objects selected it sets the same label on each of those objects.
There will be more stuff coming for grouping, the current name thing is not really for that.
2168.30 In reply to 2168.27
Hi Nick,
> 'a' is 'a').
Yeah I haven't quite gotten to doing the object property data transfer to Rhino yet.
MoI doesn't use the standard Rhino name property for holding the name because Rhino's names can only be applied to top-level objects and not to any sub-objects such as faces or edges.
In MoI sub objects are "first class objects" and can have their own individual properties assigned to them. So to support this MoI stores object properties in a custom chunk of data in the 3dm file, since there is no standard mechanism for it.
I expect to translate properties over to Rhino-visible ones when possible, like I will be setting the regular name property of the top-level object so that Rhino will be able to see the stuff that it supports. But I'll probably be worrying about that more all in one batch after I've got the properties that I want to have set up in MoI all set up first.
2168.31 In reply to 2168.28
I understand the bounds description now. Thanks. I guess what I would expect or what I am used to would be that 5x5 is 5x5. So when I'm creating real world objects and using measurments I gather, I would choose to create a "square" and then want to "numerically size and place it". Having those nubers change would be confusing to me. I am not good at drawing something on the screen where it should be....I'm better with "square 5x5x1 size, at 26.6, 20.2, 10.35 coords... So if I typed size 5x5x1 and the actual object was something different because it was set somewhere in space, I would be lost.
Could I learn a diffewrent way??? (Danny should know this answer. ie; could my approach or thinking change and acheive the same results)
Is there a way to have it act like this?
Thanks for the time.
2168.32 In reply to 2168.15
I had wanted to set it up like this originally but I had some difficulty making it work.
But I have a new idea which I'll try.
It's still good to avoid having more than one line if possible, and "Closed curve" just takes up too much space. So even with a better line wrapping I still want to keep that abbreviated to help make for fewer multi-lines with simple names.
2168.33 In reply to 2168.30
Sounds like you need to submit your more sophisticated format to the opennurbs project. ;-):-)
Show messages:  1-13  14-33  34-53  54-73  74-86
