Tangent snap question
All  1-3  4-9
Another solution
I am not sure if I am clear :)
2165.5 In reply to 2165.3
Hi mushroomgod,
Have you tried to build help/guide lines ?
Just after selected the curve tool, you can drag 2 tangent guide/help line along the end curve, just by clicking (and stay clicking) and drag the mouse more less along the tangent direction ... the helper will show the tangant snaping info.
You can then draw the curve and use the guide line to snap the 2 last control points and keep tangency.
EDITED: 3 Feb 2010 by PAQ
2165.6 In reply to 2165.5
@ PaQ :C'est bien ce que je pensais mon schéma n'était pas assez clair :D
M'enfin je vois qu'on est deux :D
EDITED: 20 Nov 2008 by PILOU
2165.7 In reply to 2165.1
Hi mushroomgod - did this get solved for you now from the replies above?
Yeah - you'll need to use straight snap, which by itself handles the first tangent, then for the ending one as described above you'll need to set up a construction line (by holding down and dragging, also with straight snap still enabled) to set up a kind of snapping guide for placing the second-to-last point.
Let me know if this still isn't clear.
2165.8 In reply to 2165.6
@Pilou Entre mon anglais pourri et tes graphs de physicien je pense que le gars est entre de bonnes mains :P
2165.9 In reply to 2165.8
Between my physicist's graph and the PaQ abstract's drawing, Mushroomgod you will be lucky if you will find your solution! :)
In any case Helpers lines are always your friends!
Show messages: All  1-3  4-9
