pencils,etc
All  1-2  3-9
2156.3 In reply to 2156.2
Excellent work (as always)!
Yes I'm curious too about the workflow. I'm trying to find the best way for pass moi models in 3DS Max for rendering with fryrender, but I still have some problem with transparent object.
Anyway you are enjoing moi!
2156.4 In reply to 2156.3
Yes----not as easy as first thought!
Good practice exercises.
Rendered in Carrara6Pro from MoI .obj file save.
Brian
ps--I think I will go back to my favourite image format--B&W!
EDITED: 30 Dec 2008 by BWTR
2156.5 In reply to 2156.4
thanks peeps. i am actualy using cinema 4d to import the models and set up. the models dont even need tweaking when i import them \0/. i export as obj. i have tried 3ds max with obj but the models dont come in nice. so i tried a few others and found that iges comes in clean
www.max3d.org
2156.6 In reply to 2156.5
Hi Dave - for 3DS Max instead of OBJ I would recommend using the new FBX export that is in the current MoI v2 beta (Sep-21 version).
However, there is a bug in MoI's FBX exporter regarding welding - you need to expand the mesh dialog and uncheck the "Weld vertices along edges" option for now when exporting to FBX. This is fixed up for the next beta release.
Then on top of that, make sure you've got the newest FBX importer plugin for Max, which you can get here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=10775855
That combination should work a lot better for exporting data into Max than OBJ.
For Cinema4D OBJ export works great.
EDITED: 16 Nov 2008 by MICHAEL GIBSON
2156.7 In reply to 2156.6
thanks, i shall pass that on to my mate. i only tested it in max because he uses it. ( i only use max now when forced to) i love how clean the mesh comes into c4d so i cant ask for more :)
www.max3d.org
2156.8 In reply to 2156.7
Pencil
Brian
2156.9 In reply to 2156.8
yes it is :)
www.max3d.org
Show messages: All  1-2  3-9
